dual rear tires
   / dual rear tires
I live in WA state (lots of rain) and the ground is clay, which means that even my R1 tires fill up with very sticky mud so I think turf tires are out for my situation, I did just finish turning my front tires around and I was surprised at how much of a diffrence that made I gained about 6" per tire and it did not seem to affect the performance any. Any how I think I'll see how it does for the time being. I do have to say this is a pretty cool site and I appreciate all the feed back I have recieved from everyone. /forums/images/graemlins/grin.gif
Thanks,
Shawn
   / dual rear tires #22
Soundguy:
yes, thanks to what I'd read on TBN before and during my search, I was real careful about the front-rear ratio.
I carefully measured things both before and after. I was probably lucky to find the turfs for the rear that would keep the right ratio.
   / dual rear tires #23
Cool.. glad to hear it. It is always nice to hear a success story where the forum came through with valuable data that helped somebody!
Soundguy
   / dual rear tires #24
Not to put fuel on the fire but here goes,
If u put wide turf tires at wide spacing what is the difference in using duals but w/ narrow tires ( they could have less over all width and even less total weight).
Someone sells sidehill mowers (PT ?) that use narrow duals because of less slip on steep hills mowing across the slope.
On our 1680 combine it has 43x66 floater rice tires or run dual or triple 18.4 tires.
Beside /forums/images/graemlins/cool.gif DUALS LOOK COOL /forums/images/graemlins/cool.gif
   / dual rear tires #25
I agree with Hoeman00, duals look cool! But, IMO if were talking weight and stress on the rear axle has anyone considered wheel weights versus duals. I've seen posts here with compacts with heavy wheel weights, the resulting stress would also be increased. I'm sure some stress would be increased from duals riding on the outside dual, but it looks to be stressful either way. The rear axles are built to handle the stress from attachments too, wouldn't a boxblade weighing 750 lbs. be more stressful than a boxblade weighing 350 lbs. Maybe some mechanical engineers need to put in their $0.02.
And again like Hoeman00, I'm just bringing up an alternate point of view, not trying in anyway to trip someones trigger. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
   / dual rear tires #26
Well.. I'm a Civ Eng.. not mechanical.. but at first glance, think of a lever.. the longer the lever is the more the weight / pressure is amplified... the dual rim extends the leverage that the axle and bearings are experiencing.
And as for weights.. the Eng's designed the system for the wheel weights, etc.. not specifically the duals.. ( except for some tractors that were designed with duals in mind.. ).
Soundguy
   / dual rear tires #27
Shawn,
I'm further up north than you near Seattle. I have turfs on my tractor and they work really well. The main difference, however, might be that my soil is glacial till (see all rocks and sand). I think that you'd actually be quite surprised how well the turf tires actually grip.
   / dual rear tires #28
Todd, Shawn,
I have turfs on my 970 and I like them alot more than my R1 on my last tractor. Now I can do work on my property and not rut it all up like I use to with the old tractor with R1.
I never thought they would work as good as they do, With all the rain we have it's better to flot on top than dig to the bottom, I have taken this tractor places on my property that I would not been able to get with the other one.
The area I live is very muddy with a high water table and turfs do a great job in the mud!
PJR
   / dual rear tires #29
It's funny... I'm a big ag tire fan.. I love those deep r-1 cleats... all my tractors had r-1's.. but I just picked up this naa, with sand tires.. I think I'm going to make that my bushhog machine for a few cuts, and see how the pasture responds... ( though the r-1's havn't seemed to affect it. much).
Soundguy
   / dual rear tires #30
Years and years ago - My father had an Farmall Super MTA Diesel With P/S and a Fast Hitch (Nice tractor). /forums/images/graemlins/ooo.gif Well I kinda missed the Dead farrow and crossed on a angle and busted the axle twice. /forums/images/graemlins/shocked.gif /forums/images/graemlins/mad.gif Here - you have a tractor on the ground on one side and big set of duals sitting out in the field for everybody to see. My dad took some ribbing from his buddies on that. IMO the big rigs are beefed up for Duals but I can't say that about CUT's.
Frontier AB13D Hay Spear (A50120)
Frontier AB13D Hay...
EZ-GO Freedom SE Electric Golf Cart (A50121)
EZ-GO Freedom SE...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A50322)
2025 GIYI GY-ZWB...
HD Bin Dump Forks (A50120)
HD Bin Dump Forks...
