Oil & Fuel Dumb oversight on 150 hr oil ch,
   / Dumb oversight on 150 hr oil ch, #11
Agree with the others, we need more info here.
Did you remember to put the drain plug back in???
If your engine oil light is on, it is clear you drained the engine of oil. But I/we are unsure that oil got BACK into the engine if the light is on and the dipstick is empty.
Could you have possibly put it in the transmission?? I am not familiar with your model either, but most tractors have a common transmission and rear end sump that is probabally around 8 gallons. Adding another gallon and a half is only a drop in the bucket and would NOT overfill it.
I too have never seen a sight glass on an engine. Let alone a sight glass AND a dipstick. The sight glass is probabally for the transmission???
   / Dumb oversight on 150 hr oil ch, #12
greasemonkeyok said:
Seems unlikely the wrong hole would accept six quarts without running over, unless it ran out on the ground.
Maybe it went into the reserve oil reservoir. It could happen?
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2023 Kubota KX057-5 Compact Excavator (A55314)
2023 Kubota...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
Miles read : 112,969 (A50323)
Miles read ...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2016 Bobcat E85 Midi Excavator (A55851)
2016 Bobcat E85...
