Dumbest mistake EVER!
   / Dumbest mistake EVER! #11
Dumb mistakes like that are what got me into the tractor trading business as a sideline. I kept buying implements that were way too big for my little SCUT. Because I was poor I'd only ever be able to buy something that was a screaming good deal. After I'd find out they were too big, I'd put them out in front of my place with a for sale sign for twice what I paid for them. Seldom did anything last more than a few days before it was sold.
Now I've starting buying the wrong stuff on purpose.
   / Dumbest mistake EVER! #12
Dont feel like the lone ranger here.....most of us have done the same thing a time or two. I recently bought a plow with 2x16 bottoms instead of 2x14's ...as indicated by the model number. As said above.....the quick hitch (Harbor Freight) with cat 2 may be your 60 dollar solution to make that plow work for you. :confused:
Thanks for the grief counseling... The Sigg story of the wrong caliber makes me feel warm inside as that was a little more than what I paid for the plow (and by little I mean LOT, and by warm I mean misery loves company).
My wife has made it clear I will NOT be starting a side business doing this :) But good idea.
As for the "buy a bigger tractor" - this plow is for the new bigger tractor... so - not going to try to take that hill - I'm happy with the recent victory - and learned new tractor whining is only effective in 5 year intervals :)
Swapping lower link arms back and forth does not sound like fun to me :) And modifying the plow, while attractive, kills the value of it - where I might be better finding a buyer and then getting a 2 bottom for me... plus - modified plows usually pull like, well, modified plows... just been my experience.
The quick-hitch option isn't a half bad idea (I knew there were lemonade from lemon people here) - off to TSC today at noon to take a peek at their hitch setup since the top link on that one is adjustable and the bins of cat 1 and cat 2 pins and bushings are an arms length away from the hitch :)
Also have some nibbles from local CL - so maybe I'll get lucky there too...
Like most everything in life that should be simple... stay tuned :)
   / Dumbest mistake EVER! #15
you might also consider fabing up something like a pat's quick hitch except not so quick hitch.
ie a piece of 2x4 box steel about 8" long. at the tractor end is a hole for CAT 1 pin to 3pt arms. (slip over arm ends) the other end has hole for cat 2 pins on plow.
could be built with a 16" long piece of 2x4 box steel anything to cut it in half from a hand held hack saw to recpt saw, to 14" cuttoff saw etc. and a hand held drill and 2 hole saws of the right diam.
   / Dumbest mistake EVER! #16
Don't feel too bad. the only thing worse than putting a cat II impliment on a cat I tractor is putting a cat I impliment on a cat II tractor. 'Specially PTO powered attachments...... Big ole tractor turn them into a pretzel!
I bought a used cat I chipper that had a nearly 90 degree twist in the spline shaft. the fool ran it off the back of a 100 hp tractor. He is lucky...............VERY LUCKY. Yeah, I replaced the shaft, and the belts were junk too.
2021 New Holland T9.565 HD 4WD Tractor (A50657)
2021 New Holland...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
Genie GTH-644 (A50490)
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
