Dump truck cylinder leaking only at bottom of travel.
   / Dump truck cylinder leaking only at bottom of travel. #21
Im guessing its just a gland seal that shot if it only leaks at the bottom of the stroke..
With two hoses, its power up AND power down. But while lowering and pumping oil into the rod side to make it lower.....there is little to no pressure because gravity is doing most of the work, and the bed is lowering with no resistance. But once the bed hits home...now the fluid actually builds internal pressure, and leaks out the bad seal.
2006 Nissan Titan Crew Cab Pickup Truck (A55788)
2006 Nissan Titan...
2023 John Deere 1025R (A53314)
2023 John Deere...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND68FDGH1824 (A54865)
2015 Freightliner...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2017 Ford F-150 XL (A53314)
2017 Ford F-150 XL...
