Dying Trees?
/ Dying Trees? #1
VirginiaAgent
I recently had a portion of my property logged. I selected several of the larger hardwoods to remain, and they were left untouched. Now, after only a couple of weeks since the loggers left, some of the the trees leaves are turning brown (One completely brown).
I have looked at them and the root system appears undamaged. Could it be that they are now exposed to more light than before, and that browned the leaves? I find it hard to believe that the trees died in a matter of two weeks.
If they are dying I need to take them down now, before my fence goes up. So what do you guys think, will the trees be ok???
VA
/ Dying Trees? #2
Do the trees have any scar marks on them? where they were hit with equipment or other logs? also could be a soil compaction problem where equipment has run over the roots a few times.... from what I have noticed most trees dont usually do to well after being taken from a forest setting into a shade tree setting
/ Dying Trees? #3
I would think if you have a Farm Bureau out there they could send some one to give you a good idea. I am not an arborist which is what you need. There are some tree's that just don't like to have their root system driven over. Did the loggers pull out stumps when they did their work? They may have changed the water table a bit. It is getting close to Fall so the tree's are starting to go dormant anyhow. Although not that fast typically.
If you are going to build near them you might consider removing them prior to building just for ease of dropping them. Are they going to be shade tree's?
My advice would be to call and talk to an arborist. Tell them what type of tree. And what your long term plan is with these tree's. They could then give you better advice. There are some guys on this forum that might just fit that description.
/ Dying Trees? #4
You don't say where you are or what kind of trees but I would first off consider root compaction. Bumper trees usually only get scared up on one side and manage to survive although they are ruined for lumber. I wouldn't be in a big hurry to take them down. They could easily lose their leaves now and come back again next spring.
Get a professional opinion.
/ Dying Trees? #6
Has it been dry lately? If the surrounding trees were removed, it allows sunlight to dry out the ground or certainly raise its temperature a few degrees hotter than before. Compaction and drying of the ground are probably two of the primary culprits. If you want the trees, I'd sure give them a chance to recover. If you build a fence, will it be very close to the trees? The type of fence and how much you disturb the ground could cause additional shock. Depending on the type of tree, there may be several things you can do to improve their long-term health. An arborist may be money well spent, but I'd try to find one who doesn't do a lot of cutting.
/ Dying Trees? #7
If they're not dying they will certainly be under stress for any or all of the reasons already given. Give them some TLC now. Use fertilizer under the drip lines and even drill holes into the dirt under the drip-line to help it get in there. Less more often is better than more less often. Water like it's a new tree which in a way it is now.
Yes, the extra sun they're getting could cause more stress and turn leaves brown. Just think about when you go get a tomato plant from say Wally World. You have to let it acclimate to your yard and sun conditions or you risk stunted growth and/or death. I typically plant my transplants under a teepee of green branches and as the branches die the transplants get more and more sun. You can't do that with a tree, but you can give them plenty of water so they don't dry out and "wilt".
This is what I would do this time but I can't test it. When I was cleared, several years later my big oaks all rotted from the inside and died, over a period of a couple of years. I didn't do any of the above but feel like it might have made the difference. The comments about calling a pro is probably an even better choice though. :eek: My trees will never be that size again in my lifetime. :(
/ Dying Trees? #9
Any chance of compacted roots? What type of equipment was used to remove the other trees and did they get under the dripline of the trees you saved?
I saw a guy grade his front yard and spread some topsoil, all with a tracked skid-steer, I believe...never saw any other equipment out there. He did it in the fall. The next spring, every single one of the White Oak trees he had saved were dead as a doorknob. Everything about the work seemed OK by me, and it didn't appear that he filled significantly near the trees. Nevertheless, they croaked.
The only thing I could figure was him working all over the tree roots with equipment. Killed them dead.
Sorry to hear...I hope they're OK. Love trees.
/ Dying Trees? #10
As mentioned before, compaction can cause some real problems. However, the tree may not be dead. Usually it takes some time for compaction problems to show up.
Check to see if the twigs are still alive by sharply bending twigs to see if they are brittle or not. Brittle twigs mean that part of the branch is dead. Also check to see if the buds are still alive. Dead buds will break off. A third check is to scrape the bark off of small twigs to be sure the cambium layer just under the bark is still green.
If all three tests come back positive, the trees are still alive.
/ Dying Trees?
I'm in the Hampton Roads area of Virginia. It has been very dry the past month, and very hot.
I think you guys have hit it on the head about this likely being a combination of soil compaction, dry ground, and more sunlight than they are used to.
The loggers left the stumps, but I have had an excavation company pulling them up for the past week. The loggers used massive skidders and a feller buncher, 40 thousand pounds each.
I told the excavators not to pull stumps within 20 feet or so of the trees to save. I wonder if that was still too close.
The fence is going to be pretty close to a couple of the suspect trees. I think, as suggested, I'll try to talk to an arborist and hopefully give them some time to recover. The analogy about a tomato plant going in to shock and wilting seems like it would logically apply to a large tree as well.
Thanks for the insight. VA
/ Dying Trees? #12
I would talk to an arborist right away. This is a critical time of year for the trees, since they need their leaves to start sending energy back to the roots to survive the winter.
/ Dying Trees? #13
Cool. I grew up in Hampton Roads.
Regarding the "20 feet"...it's more of a dripline thing than a distance thing. If heavy machinery stays outside of all limbs on a tree if the canopy was projected straight down, the tree should be OK. If they are within the "dripline", you risk compacted roots. Larger trees require a larger berth. And those skidders are certainly heavy enough to do some damage.
/ Dying Trees? #14
Several potential issues
1) Feeder roots can extend like 5 times further than the tree canopy. These roots are small, and driving heavy equipment over them espically on uncompacted soil can break or damage them - this usually takes a while to show up.
2) Sun plants can get sunburned. Depending on how many other trees were nearby they could have been partially shading the tree. Try it for yourself, take a houseplant outside and set in direct sun see how fast it reacts.
3) Physical damage to tree which should be obvious.
4) Dead/dying trees attract insects, if any debris is left from logging insects could be attacking only remaining food source.
An Arborist would be best, but in the mean time Bayer Advanced Tree and Shrub Care - Bayer Advanced
Will do wonders if you get it applied ASAP.
Good luck!
/ Dying Trees? #15
In additional to extra sun they might also be getting more wind than usual which can dry the leaves out. I'd wait at least one season before deciding whether they were dying or not.
/ Dying Trees? #16
I cleared a big oak that was surrounded by thick brush a few years ago and the next year I was pretty sure it was dead. But it came back stronger than ever. I suppose it was stressed by the change in conditions; i.e. more sunlight, different moisture conditions, wind, etc. The tree is doing great now and I think it is better off in the long run.
Don't make a hasty decision just yet, I would also suggest waiting until at least the end of next season to determine the true condition.
With that said, there is also the possibilty (small I would think) that the trees have some sort of disease. I know oak wilt can kill a red oak in a matter of days. It's endemic here in Central Texas, we've lost literally millions of trees, so you might consider the suggestion to get an arborist out to have a look.
/ Dying Trees? #17
Trees are alot more sensitive than most think., You can kill an oak tree by dumping a 3 inch layer of topsoil around the base. When I worked for Huffman we did an excavation on the Tennessee river and didnt have alot of room so we had to put the spoils in the woods. We had 3 rules dont contact a tree with a machine, dont take and topsoil, and we had a time limit till spring to have that removed.
When they clear cut I hate to see them leave some trees like sour dood because they daie off shortly afterwards. My first neighbor had a lot of trees he damaged with a tractor and a rental dozer they looked dead some stayed dormant 2 years.
/ Dying Trees? #18
I had a similar problem and found a tree company called Bartlett Tree Experts. They did a root invigoration. My oak is now coming back strong. Big trees require special care. Try finding a Bartlett Arborist
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
