e Grove Eddie1c Locust Grove Ga
   / e Grove Eddie1c Locust Grove Ga #1
eddie1c
71 ford 3000 and 2006 Massey Ferguson 1552 w/cab
I just bought a 2006 Massey Ferguson 1552 w/cab and it has a QPS transmission. When you shift into #2 in any range (Rabbit,Turtle or Snail) it doesnt do anything and puts up an error code. Gears 1,3,and 4 work fine. Is this a problem with an electrical solonoid ? Or is it something else? Thanks Eddie
Transmission fixed!! It was a wire pulled loose from the pin connector to the control module located on the left side just under the floorboard. Possibly a stick got it. The underside of the tractor needs a skid plate to protect the wires and transmission lines that are exposed. I am going to design one in my metal shop that will be easy to remove for service, but will protect the underside. It was an inexpensive fix!!
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
2022 Harley Davidson Electraglide (A55973)
2022 Harley...
JLG 1255 Telehandler (A55315)
JLG 1255...
