E350 di
   / E350 di #1
Jefflw6
E350 di
Just picked up a E350. Only has 700 hrs on it.
Never owned one before.
What’s the trick in opening the hood?
Looks like the air filter is blocking it.
Terrie dot find an old operator manual. No luck.
   / E350 di #2
I used to own a 35hp Mahindra. The air filter was on a metal tube that slid through an opening in the hood into another pipe fitting on the engine. I had to pull the air filter and pipe off to open the hood which had two latches to actually open the hood.
   / E350 di #3
I believe it's similar to my 5005, both the exhaust and air filter pull off (up) and then the hood tilts forward. If the 350 is also similar the batter is in the front of the tractor and you need to remove the grill to access/replace. Good Luck!
2025 GPS Trailers (A56857)
2025 GPS Trailers...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
UNUSED DSBREAK DS140A HYD BREAKER W/ BIT (A60432)
UNUSED DSBREAK...
1999 Wallace Trailers Tri Axle Low Boy Equipment Trailer (A59230)
1999 Wallace...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
