Early 444 Stator
   / Early 444 Stator #11
There are several tests using a multimeter that can be conducted on the stator as it sits right now. The only test you cannot do, requires the engine to be running so you can use the multimeter to check the amount of AC produced by the stator.
If you have used a multimeter before, then please tell me so I do not have to instruct you.
The second motor appears to have been blasted with some sort of media. If I am right, then you must dismantle the engine partially to see if that media got into places where it can do serious damage.
   / Early 444 Stator
I'm 1 step away from removing the stator from the machine, so your instruction won't be necessary. As
stated earlier I will have it tested by the shop. Thanks for you observation of the newer motor. I will remove the cooling shrouds and inspect.
2020 Kubota MX5400 (A50123)
2020 Kubota MX5400...
UNUSED LANDHONOR PHA-16-2C HYD HITCH ADAPTER (A51248)
UNUSED LANDHONOR...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
2025 CFG Industrial M-DRG (A50123)
2025 CFG...
