EarthForce EF-5 enhancements
   / EarthForce EF-5 enhancements #1
MChalkley
Elite Member
Eastern Virginia
EarthForce EF-5 mini-TLB (2001)
While I don't expect this thread will become quite the behemoth that the "L4310 enhancments" thread did (and I think I really hope it doesn't), there are a few things already on the "must have" list for the EF-5 that aren't there already, and a few things that will be necessary because of my particular needs. Others will come up as I go along, of course, but here's a starting point:
Gauges - Existing gauges, (not idiot lights) as best as I can remember, include engine oil pressure, water temperature, hydraulic oil temperature (at the tank sump), fuel level and voltmeter. An idiot light signals hydraulic filter flow restriction, hence the need to change it (I hope I never see that one come on).
Planned additions, and the importance I place on them, include tachometer (mandatory, unless my comments to the factory reps about how dumb it is not to have one have been acted upon already and it actually shows up with one), TiltMeter (mandatory - Rick at R&B is already "on the job", so I'm not losing any sleep over this one), hydraulic gear pump pressure (mandatory), gear pump oil temperature (luxury - but I'd like to get a pressure sending unit that also sends temp, which would give me two functions for one), gear pump flow (luxury - not likely any time soon), HST pump oil pressure and temp (luxury - but very informative, I expect, so it's fairly high on the list), pyrometer (very useful, so it's high on the list), turbo boost (luxury, but very informative), air filter restriction (very useful - at least an idiot light), engine oil temp (luxury), and water temp (redundant). Ideally, I'd like a single gauge to show the gear oil temp, HST oil temp, engine oil temp, and water temp. If it were the digital type, it could have an alarm to signal overly-high temps, a big plus, and it would only need to be a single gauge, so it would take up a lot less real estate. Also, I could possibly even add an engine oil pressure sending unit to a digital unit, thereby having a very important oil-pressure alarm. Alternatively, I could do like I did with my L4310 and use a standard gauge with a rotary switch to select the appropriate sensor. The hydraulic pressure gauge could also be digital, but the ranges are very different - 3500 psi for the gear pump and 7000 psi for the HST, which might be a problem). Also, hydraulic pressure fluctuates so much that I'm afraid a digital readout for this function wouldn't be very practical. Suggestions for sources of the gauges and sending units would be very much appreciated.
Lights - The EF-5 already comes with front headlights, two front worklights, four rear worklights, and complete road lights - marker ligts as well as stop and turn signals. However, subject to further review, I'm seriously considering replacing (or supplementing) the existing bulb-type ones with LED lights. I do a pretty fair bit of on-highway travel (usually for very short distances, fortunately), so high visibility is absolutely essential. Suggestions for low-cost, quality LED light sources would also be appreciated.
Other stuff:
Loader attachment level indicator - I need an electronic level indicator that can be reset to indicate "level" wherever I want it. Rick at R&B is also working on this one. He recently sent me a prototype to test and it would be fine for a loader level indicator, but I (as usual) want more. The great thing about his unit is that it's wireless, so you just mount the sending unit on a bracket on the back of the bucket, set it so it's signaling level when the bucket is level, and you're done. So many of you may be interested in this model already. What I need, though, is a unit that can be attached to the back of the quick-attach plate of my loader, and electronically reset to register "level" anywhere I choose. The reason for this is that different loader buckets (not to mention other attachments) are level with respect to the ground at different attachment point angles. So I want to be able to push a button on the panel indicator in the cab to tell the unit that the current attachment is now "level". As I say, Rick is working on this one now.
Another enhancement will be locking caps for the fuel and hydraulic oil tanks. Suggestions for a source for quality (preferably keyed-alike) caps would be appreciated.
The last enhancement on my "I don't even have an EF-5 yet" list is a means of securing the backhoe-mounted auger when I'm not using it. My EF-5 is going to have a quick-attach plate on the backhoe (heavy equipment folks call them "couplers", I've learned), so I can easily switch between various buckets and a hydraulically powered auger. Given the fact that that the end of the dipper, when retracted, is about 3' off the ground, and the auger and bit assembly will hang down about 5' feet, it doesn't take a rocket scientist to figure out that something's going to drag if I don't do something about it. I'm thinking about welding one of those metal plates with a keyhole-shaped hole in it to the dipper, so I can chain it up fairly tight against the dipper. What do you call those things, anyway? (I've always called them slotted chain pad eyes, but I don't know if this is right or not.) Whatever they're called, a source for a machined one would be appreciated. I'd rather not use the burn-one-out-with-a-torch approach for my new baby.
Oh yeah, I almost forgot: At some point, I'd like to add an air filter pre-cleaner, and a bypass engine oil filtration system - probably about the same time I switch it over to synthetic oil - at 250 hours or so.
In addition to the aforementioned pleas for sources, comments, suggestions, and donations /w3tcompact/icons/wink.gif would also be appreciated.
MarkC
   / EarthForce EF-5 enhancements #2
Mark,
Sorry no donations from this source, although I sure don't blame you for giving it a shot./w3tcompact/icons/smile.gif I had a thought on the slotted chain thing. A know a guy here that works for a metal fabrication shop who showed me a lazer burning unit they have. This thing will burn up to 1/2 metal and leaves a cut that looks almost polished. I don't know it the set up charge would be to much for a one off, but you might look and see if anyone in your area is running lazer cutters.
MarkV
   / EarthForce EF-5 enhancements #3
Hey Mark, I got some Dylithium crystals if you want to re-do the power plant. /w3tcompact/icons/laugh.gif
Keep the greasy side down.
Mike
   / EarthForce EF-5 enhancements #4
Geeminy christmas Mark, your'e **** (thats **** in the good sense of the word). Only you would come up with all that stuff on the tractor. I think a 747 cockpit would make you like a kid in a toy store, good luck with all the extras on your new tractor, Rat...
   / EarthForce EF-5 enhancements #5
You might want to look into Murphy switchgauges. These are mechanical gauges that shut off the engine if it overheats or loses oil pressure. We used to install them in just about everything when I was a mechanic at an International Harvester/ Sperry- New Holland dealership. That was years ago, they might even be digital now.
Mike - You wouldn't be part Ferenghi, would you? /w3tcompact/icons/laugh.gif
Actually, you've given me an idea. My wife insists that everything has to have a name. The L4310 was "Kubbie" until the time I hit a natural gas main with the auger (Miss Utility marked the line in the wrong place), at which point one of the guys I was working with christened it "Sparky", a name my wife didn't entirely appreciate... But, perhaps the EF-5 will have to be "Enterprise". /w3tcompact/icons/wink.gif
MarkC
bgott - They sound interesting. I don't think I'd want them to shut the engine off, but they could sound an alarm just as easily. I haven't been able to find any high pressure gauges on their site yet, though. Maybe I'll call them. Thanks for the lead!
MarkC
   / EarthForce EF-5 enhancements #9
Take a look at SPA digital gauges at http://www.spatechnique.com/. These gauges have user definable set points, dry contacts to trigger external devices and are very versatile. The dual series will get you two in the space of one. These are 4-20 ma gauges so give them a call, they have many pressure and temperature transducers that are not on their web site. Top notch stuff but not real cheep, reasonable though. Bob.
Thanks, Bob! Definitely worth a call!
MarkC
   / EarthForce EF-5 enhancements #11
If you need a source for LED lighting, check www.whelen.com -- they produce emergency lighting / industrial lighting for most applications. They were also one of the first companies to market LED lighting
for emergency vehicle / construction use. We have started adding LED's to some of our patrol cars and they really do seem brighter in sunlight -- not quite the brilliance you get at night with strobes, but for your use, definitely the best choice.
   / EarthForce EF-5 enhancements #12
Now, I might be off a little on the picture, but just where do you put the tiller on this Earth Force vehicle?
<=======/w3tcompact/icons/laugh.gif
Mike
Last Tuesday, I went to see Jason @ Folcomer Equipment and picked up a couple of the items I bought from him. One of them that's applicable to any tractor with a FEL is the FFC bolt-on edge. I thought they looked quite interesting on their web site, so I went ahead and sprang for one for the EF-5's 74" 4-in-1 bucket and another for the 78" large capacity bucket I had built. They're about $400 for a 72" one, delivered.
When I picked them up, I was quite surprised - they're much heavier duty than I expected them to be; well, more aggressive might be the better way to put it. Anyway, here's the web page I found them on: http://www.ffcattachments.com/cdrom/buckets/BK10.htm. I got the wide tooth model. Don't be fooled by the pictures - those teeth are not nearly as small as they appear: they're 4 3/4" wide at the bar and 5 1/2" long. Rather than coming to a sharp point, they're a bit rounded with respect to width and tapered to an edge with respect to thickness. They seem to be made of extremely high quality steel. I'm anxious to try them. It's already pretty clear that regular teeth will no longer be needed on the bucket, using this edge. Plus, an advantage of this style of edge vs. traditional teeth is that the bucket can still be used for smoothing by just flattening out the bucket. I'll see how well that works, too, when I get to use it, but it seems a viable concept, anyway. This isn't of too much concern when you've got a 4-in-1, because you can always open the bucket to get a flat edge, but the ability to have a lot more teeth with this edge may be very useful for breaking up clods, cleaning up debris, etc.
For smaller tractors, I'd strongly suggest considering the narrow-tooth model, though - as I said, the teeth on the wide-tooth model are serious. I'll post a picture of it with a quarter laying on the tip of a tooth to give a better perspective of the size soon.
MarkC
Re: Pic of bolt-on tooth edge
Here's the promised picture of the FFC bolt on edge, wide-tooth style. The coin laying on the tooth is a quarter.
MarkC
Re: Pic of tie down chains
Since the EF-5 has 4 tie-down points, it's better to use 4 chains to hold it on the trailer, rather than run 2 long ones from one side to the other, the way I did it with the Kubota. I wanted to make up 4 separate chains with a big hook on one end that would clip in the tie down hole without any possibility of falling out and a grab hook on the other end to hook onto my trailer tie-down points. Additionally, I wanted to use a spring binder, so it could automatically take up the slack when the EF-5 bounces on its tires - especially important when I get around to putting the Michelins on it.
The only thing I could find in the way of chain, hooks and binders locally was Chinese junk (again, my usual disclaimer: not implying that everything made in China is, but this stuff was). So, I called up the guys at Labonville since they've always come through for me before. Attached is a picture of what they sent me, after I put the hooks on the chains. They cut the chains to length without charging me extra. It's all G80 or G100 stuff, made in the US by CM, or in Austria by Pewag (that's right, for you long-timers - Pewag of square link choker chain fame). (The coin laying in the slip hook is the aforementioned quarter...) Notice the really heavy duty alloy guards on the slip hooks, too. Even the binders are made in the US.
Now, if I just had an EF-5 I could bind down, I'd have what I need to do it... /w3tcompact/icons/smile.gif
MarkC
   / EarthForce EF-5 enhancements #16
Mark, that really is going to be an impressive piece of equipment (if you ever get it and get it all customized)./w3tcompact/icons/laugh.gif
Bird - If it's as impressive as your sig, I'll be fat, dumb and happy. (Two down, one to go... /w3tcompact/icons/laugh.gif)
MarkC
   / EarthForce EF-5 enhancements #18
Yeah, Mark, ain't that impressive; wish I could take credit for it./w3tcompact/icons/laugh.gif
Bird - I know what you mean - literally...
MarkC
   / EarthForce EF-5 enhancements #20
Mark\'s lucky quarter...
<font color=blue>… The coin laying on the tooth is a quarter…The coin laying in the slip hook is the aforementioned quarter...</font color=blue>
You’re sure getting a lot of mileage outta that quarter Mark…
When the Earthforce comes… take a picture again…with that quarter… /w3tcompact/icons/tongue.gif {and maybe JB Weld it to the undercarriage…}
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE 4450 TRACTOR (A60430)
JOHN DEERE 4450...
JOHN DEERE 8200 18 ROW GRAIN DRILL (A60430)
JOHN DEERE 8200 18...
2020 CATERPILLAR 302.7D CR EXCAVATOR (A60429)
2020 CATERPILLAR...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2434 (A60432)
2434 (A60432)
