_RaT_
Super Member
- Joined
- Apr 19, 2000
- Messages
- 5,855
- Location
- Peoples Republic of Northern CA.
- Tractor
- Kioti 3510-SE HST
It may be swirling, but its not got much room to do it, remember, the fuel is not introduced till about top dead center, that gives it very, very little room in a very confining and pressured packed enviroment. Most of that cylinder never gets to see the fuel mixture like in gas engines. Actually, yes, an intercooler I am told can reduce the inflow air temperature allowing for even more air in the cylinder simply because cooler air is more dense. Tubos on gas engines can create such high temperatures that early failure due to overheated surfaces can result. With a diesel, a lean mixture will mean a cooler engine unlike a gas engine where it could actually melt the pistons (like I did to my old fuel injected VW). All said, I understand that even the first diesel was designed to use a air compresor to introduce more air into the cylinder or positive inflow pressure. Relying on the piston to do all the work while pulling it through the various passages really sucks, much like my non turbo 7.3 L Navistar. Rat...
