Easiest way to remove 422 battery
   / Easiest way to remove 422 battery #1
bullitt
Pittsburgh PA
pt422
The battery in the 422 is shot. A casual inspection does not reveal an easy way to remove the battery.
Unfortunately, the battery will require replacement in advance of the engine upgrade.
Any suggestions?
bullitt
   / Easiest way to remove 422 battery #3
I had to remove the muffler to change my battery. I have one of the "new" welded PT-made mufflers though (which may be larger than the Kohler muffler).
   / Easiest way to remove 422 battery #4
Bullit,
The bad news, you do have to remove the muffler. The good news, pretty easy to remove the muffler. Is your battery still under warranty. Curious that it failed so quick. Let us know what you end up with for a battery.
Duane
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
KOBELCO SK170-9...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
BLUE DIAMOND HYD 16" SERIES 2 COLD PLANER (A60429)
BLUE DIAMOND HYD...
