Leejohn
Elite Member
Everyone knows how hard it is to see the oil level on the dip stick. I have a way that is easy, been holding up to post this, but here it goes. This is only for checking not running with it.
All it takes is a Bunn coffee maker cleaning tool and a rubber grommet. Bunn has 2 one is short and a long one, the bigger tractors well need the longer one. The tool should be the spring one. Set the grommet the same as your dip stick as a stop and so you don't drop it in the sump. Now check the oil and see how easy it is to read.
This well work on any sump as long it is long enough, and don't forget the front axle if 4WD.
As easy as ABC !!!!!!!!!
