Eight Foot Oliver Pull type Disc
   / Eight Foot Oliver Pull type Disc #1
Dick L
Edon Ohio
Oliver 77
I am rebuilding it or building it all in how you look at it.
It was run over by a bulldozer 20 or so years ago. Dad bought it new in the late 1940's My guess would be 1948 or 1949. The frame was bent and broke thru the bolt holes so I have been bending and drilling angle iron for the frame. I took one gang apart today which had a bent 1 inch shaft. I now have it straightened. I need to find the bearing spool assembles for it. I called around today with no luck. This Oliver disc has 6 1/2" spools. The John Deere spools are 7 inch. I can machine a quarter of an inch off both ends but am not sure the bolts that hold the caps together will match the upper brackets. Does anyone have any idea where I could order Oliver repair parts for this disc?
I just today loosely bolted the frame for the left rear together. When I get bearing assembles and new blades it will start to look like a disc.
   / Eight Foot Oliver Pull type Disc #3
To find oliver parts an agco dealer would be the way to go.
What size arbor bolt do you have? CaseIH uses an 1 1/4" square and they use cast iron spacers but there smallest is 7 1/2"
The Case IH parts are resonably priced, we sell three major brands of tillage equipment equipment and there prices help us with other makes as well!
To have wider spacing would give you better penetration!
   / Eight Foot Oliver Pull type Disc #4
dick,we have farmed with oliver/white/agco allis equipment for over 50 years,i may verry well have a couple of 8footers out back in the scrap pile. if you like i can look for you. im still running mostly oliver equimpnt and ive been able to get parts from the agco allis/duetz dealer and from a few vendors on the web.
Hey 1950 T, If you are interested in selling the old discs I might be interested. It would be quite a trip for an old man but I think I am still up to the task. Not so sure about Dixie. Dixie be my wife. We are almost connected at the hip. When traveling I need her snoring to keep me awake dontchyaknow :)
You wouldn't tell her I said that would you?:eek:
2018 Ford Transit 350HD Handicapped Van (A55788)
2018 Ford Transit...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A55787)
Caterpillar...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
2007 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2007 GENIE...
2012 Club Car Precedent Electric Golf Cart (A53424)
2012 Club Car...
