Electric Airless Sprayers
/ Electric Airless Sprayers #1
Red Horse
Veteran Member
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Any opinions on these? My son has a Graco Tradeworks 150. Used it on my barn last year applying c Cabots solid water base stain. Worked well -from time to time- but always had to make adjustments and cleaning is a PITA. I'm having my house resided now with preprimed cedar clapboards. I'm doing the staining. Applying another coat of oil based primer and then a top coat of solid water based stain-Ben-Moore Arborcoat. theycall it stain-might as well be paint.
As i'm going to be following the carpenter as he completes sections i will be jumping back and forth between oil based and water based products. Im thinking I might be ahead of the game if I buy a self contained sprayer like the Wagner 570/590. Onlything I;m cleaning then is the quart cannister as well as the sprayer itself. Cpmp[ared to the long hose on the Grayco, the 2' long pick up tube etc.
One other thing, I have a boom lift so its not like I need 40' of hosebecause I'm on a ladder.
Appreciate any opinions.
/ Electric Airless Sprayers #2
I've had one similar to the Graco for 10 years and use it for everything. It attaches directly to a 5gal pail. I don't have to adjust anything, cleanup isn't so bad- just let water circulate in a loop for 5-10 minutes and change it a few times. They do waste a lot of paint, I'm guessing half the paint goes in the air rather than on the wall.
The little ones like the Wagner are OK I guess, but you're going to be adding paint all the time. They hold a quart and spray 1-2 gallons per hour, do the math. They also don't have the coverage and flow that a larger system will have. It takes a lot of paint to cover cedar.
You say you have a boom lift, not clear why you need to jump back and forth. You could follow the carpenter the whole way with the primer. Then come back and do finish coat. If you really need two sprayers, I think I'd buy another commercial unit rather than the small one.
In either case, I wouldn't just spray, I'd also roll or brush to get good adhesion. I use a roller while I spray, go right back over the section I sprayed with more paint and roll it on really hard. My experience is just spraying will peel sooner than rolling.
/ Electric Airless Sprayers #3
I really like my Titan 290. It holds 5 gallon pails. I've never adjusted it just sprays all day. I used oil based stain on my log home, and rough sided hemlock pole barn. Clean up was easy, run mineral spirits through it .
/ Electric Airless Sprayers #4
Had the Wagner cheapie (you know, little yellow one) that I painted the whole inside and outside of my house with. 1 cup of water to 2 gallons of paint for thinning and just stick the hose extension into the pail... simple and cheap. Cleanup was 2 gals of water ran through it...
Beez-thxfor comments. And for starters we are on same page- I view spraying as a process to just get the coating from the can to the surface-it then needs a brush for the complete job.
As for jumping back and forth, what I mean is as a section gets sided, I will follow up with the prime coat-oil based. Then ideally next day I'm hitting that with top coat of water based Arborcoat. Or I might do a small section with oil in AM and tyhen go back to previous days section with top coat in PM. Keep in mind, unlike a contractor I am not concerned about production all day long- if I'm faced with bright sunlight I'm not applying.
Today? we had rain-so I'm doing Azek trim boards inside with Valspar latex
Attached picture gives you an idea of what I'm dealing with. A lot of small runs vs big expanses Again I can't stick with one product if I want to keep up with the residing
/ Electric Airless Sprayers #6
It's been nearly 30 years since I spent the better part of 2 days painting the exterior of my parents' mobile home with a Wagner Power Painter. It worked very well, but was noisy and perhaps the worst part was the vibration. So that Wagner 570/590 sure looks good, but I've never used one.
/ Electric Airless Sprayers #7
I can second that Titan, I used a similar one and flew through it. Just wondering but is it ok to put water based on top of oil. I was always told it was the other way around. Water based first and then oil on top other wise you will have peeling.
/ Electric Airless Sprayers #8
Oil base primer and latex topcoat..
/ Electric Airless Sprayers #9
Friend gave me one, it did not work for him but I painted whole barn with it with minimum problems.
Guys- thx for responses.
As to water based on oil primer, that is the accepted method-at least for red cedar clapboards. The boards come pre primed with an oil based product. I have had some "800 help desks" say put two coats of water based solid stain on top of that and others say another coat of oil primer (that seals the nail holes) followed by one topcoat of solid water based stain.
That is the route I'm going. the guy who is doing the residing is an experienced guy and that is his opinion plus the Ben-Moore help desks plus my local dealer
/ Electric Airless Sprayers #11
I bought an airless sprayer from Lowes 4 or 5 years ago. At the time, I was just wanting to stain about 500 feet of privacy fence, so I picked up a less expensive model, one with a 2 gallon reservior. Works great and I've used it far more often than I anticipated.
If I can ever figure out a way to break it - I'll replace it with one that feeds directly from a 5 gallon bucket. Life would be so much simpler.
/ Electric Airless Sprayers #12
We have a titan. Works (ed) great. Issues is that you have to keep using a sprayer or it begins to fall apart. Seals get gummed up. I ended up having to tear ours apart, clean, purchase a few things and it appears to be working correctly again. Also, in the winter you want to watch for freezing.
/ Electric Airless Sprayers #13
I have to paint a barn and silo before Winter.. I'm thinking of renting an airless sprayer.
/ Electric Airless Sprayers #14
/ Electric Airless Sprayers #15
Anybody out there used the electro rotary airless painter, just picked on off e bay havent used it yet, it's made of stainless and seems well made, made in the USA when we made good stuff,I'd say in the 60s or 70s.
/ Electric Airless Sprayers #16
Not sure if this works for the quart size airless sprayers as I have never used one. I often use the quart size siphon sprayers. I get a quart size freezer bag and line the cup. Use the bag that you press to close not the type that has the slide to close. I roll the top of bag over the cup, fill with paint then attach to gun. Once done, I pour leftover paint into a container and throw the baggie away. No mess in the cup. Cleaning the gun is much easier than the cup full of paint. I have been using these bags for years with all types of paint products. Never a problem.
Now I see that cup liners are being sold. HF has them but I have not tried them.
/ Electric Airless Sprayers #17
Not I see that cup liners are being sold. HF has them but I have not tried them.
Our Graco came with a half dozen bags to go in the paint cup.
Aaron Z
/ Electric Airless Sprayers #18
Well, I learned something else new on TBN today. I have a one quart air, not electric, paint gun but never thought about using a bag in it, and never knew cup liners existed.
/ Electric Airless Sprayers #19
Just throwing this out there.
I have seen commercial grade Graco airless sprayers for sale at several rental places over the years, usually in the $200-$400 range. Nice thing is, pumps are rebuildable (pump pack kits) can use 100' hose (comes with 50") and can use a 1 gal to 5 gal paint bucket. Most are on wheels so easy to move around and brother they can put out the paint. I have rented several and never had an issue. ( For work I use Graco airless sprayers for highway traffic paint, so I am a bit of a "fanboy"):D
2013 Moritz Trailer (A63116)
2013 Moritz...
Mini Skid Steer (A60352)
Mini Skid Steer...
New/Unused IRGC40 Mini Golf Cart (A61166)
New/Unused IRGC40...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
Location (A63109)
Location (A63109)
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
