Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,331
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Coming anywhere close to the real weight of the vehicle was just plain luck.
The air pressure in tires does not directly support the vehicle, it stiffens the sidewalls which are what really supports the vehicle.
There are two ways to demonstrate this for yourself.
1. Draw a force diagram on the steel wheel at the center of the tire. Air pressure is uniform completely around the wheel, and can not sustain an upward force.
2. Reduce the air pressure in the tires to about 5 psi. The area in contact with the ground increases, but it does not become 6 times greater than the contact area of the same tire at 30 psi.
It may have been just dumb luck but it worked pretty close.
Chris
