Electric Drive Motor Retrofit
   / Electric Drive Motor Retrofit #103
Looks like it’s all hydraulic too. Pumps driven by the electric motor. Seems like that would be a fairly easy conversion to the PT.
   / Electric Drive Motor Retrofit #104
For the 20% efficiency gain, I would think that they would have it be electric drive vs hydraulic driven off an electric motor.
That is how most electric forklifts are setup.
Aaron Z
   / Electric Drive Motor Retrofit #105
Works for 2 hours and charges for 4 hours. That’s exactly what I’ve been looking for.
   / Electric Drive Motor Retrofit #106
It said something about it can work while it's charging.... what could that be about?
   / Electric Drive Motor Retrofit #107
I assume in a barn or something, where your not moving far, you could run it while plugged in.
   / Electric Drive Motor Retrofit #109
Maybe to power stationary things like water pump, chipper, splitter, concrete mixer, massage recliner, hot tub you know the usual things.
2022 INTERNATIONAL MV607 (A58214)
2022 INTERNATIONAL...
525 (A52708)
525 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
STEEL HEADACHE RACK (A52708)
STEEL HEADACHE...
1997 Peterbilt 378 Tri-Axle Heavy Haul Truck, VIN # 1XPFD69X4VN428289 (A57453)
1997 Peterbilt 378...
