electric fence not acting right!!!
   / electric fence not acting right!!!
I really think that you have a short. I have never seen a fence with all five strands hot. Around here we make one or two hot and the others are grounded. That way if you touch two wires you have touched a hot one and a ground. If you really want all five hot. Try disconnecting one at a time and see if it does not pick up shock when one of them is out of the circuit. If it really is the ground and it can be. Try making every other wire hot and ground the others. That is the way the ranchers do it who have 50 miles of fence
Everyone here that I've talked to runs all their strands hot. I have a parmak book and a gallager book and both show that both methods can be used. Here is a parmak link showing both strands hot with earth ground.
PARMAK USA - Recommended Outdoor Installation
hmmmm, I do however have a utillity ground closer than 50' to my ground rods. Actually the utillity ground is on one side of shop about in the middle and charger grounds are on adjacent side . I'll disconnect ground wire from utillity ground just for a temporary fence test and see if this is the problem. If this is it I'll move the utillity ground farther away.
Ken
I went out an unhooked utillity ground and touched fence with no change. Hopefully tomorrow I'm going to have time to look more closely for a short somewhere. I didn't install disconnects so disengaging parts of the fence aren't that easy especially with animals inside. I'm also not ruling out that this may be normal for our drought conditions.
Ken
   / electric fence not acting right!!! #13
If you have instruments that show 5000 volts between a t post and hotwire, then it is normal. A short will drop voltage EVERYWHERE along your fence to near zero. Only on very long fence runs when the short is at the other end will you find any voltage near the charger.
2500 volts will get the attention of anything...
Thanks John, I'll check tomorrow with gauge.
Ken
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
1996 Ford F-250 4x4 Pickup Truck, VIN # 1FTHX26G1TEB82118 (A51572)
1996 Ford F-250...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
