electric hydraulic valves with toggle switches
   / electric hydraulic valves with toggle switches #41
   / electric hydraulic valves with toggle switches #42
The one he linked is a "diverter"valve, I thought you wanted independent control?
SPENDIN MONEY TODAY!
Just got off the phone with Melissa at Markham, have a toothbar and grapple ordered. I was expecting a week build time and she says 'ok, we should be able to ship these tomorrow'. :D
So now i have to get busy on this remote. I guess the first question is how do i determine if the Bobcat is an open or closed center system, or more directly, which valve would be appropriate for an independent control on this setup. Any idears? I did some looking and saw a note that the WR Long kit for the Kioti was a diverter 'because of the valves, on most it's a 3rd function'.
Not sure what to make of that.
   / electric hydraulic valves with toggle switches #43
You will not be disappointed with the Markham (now Gator) grapple, I can assure you!
Your tractor is OC (open center), does your FEL valve have seven hoses connected to it? , if so, then try to identify the port labeled PB or BYD (abbreviations for "power beyond". Trace that hose and note where it connects to.
Once we are sure of all that-we can proceed to valve and switch you will need.
Might want to start a new thread also-you are kind of hijacking this one;)
   / electric hydraulic valves with toggle switches #44
Astute observation Kenny! Sorry folks.
I'll do my homework and get a new thread started. Hopefully will be able to document it sufficiently for future rookies like myself. :)
2018 Genie GTH-5519 (A50123)
2018 Genie...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A53426)
2015 INTERNATIONAL...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
