electric metal shears?
   / electric metal shears? #11
I have Milwaukee shears and a kett set with shears and nibbler.
Nibbler is my choice for roofing it follows the contours easier.
tom
   / electric metal shears? #12
Kett makes my "double cuts" and Milwaukee makes my Uni-shear. Depending on your "wastes" considerations, I like the double cuts better.However it takes a quarter in waste strip out of your material, while the unishear leaves one side straight, the other not.
David from jax
   / electric metal shears? #13
I have the $45 Orange HF ones and have cut 14ga with them, they work great and are one of my fav. HF tools :thumbsup:
   / electric metal shears? #14
I've had one of these for several years and am happy with it. I don't know how well it would work on your existing trailer body. I guess it's a Uni-shear copy. The blades are little carbide blocks that can be sharpened and adjusted.
18 Gauge Sheet Metal Shear
The body saw like in this ad for $9.99 is another option.
Automotive
   / electric metal shears? #15
The link Brad posted looks like my Uni-shear, expect mine is rated for 10 guage steel. My double cuts are rated for 14ga (I think)
David from jax
   / electric metal shears? #16
I don't think any sheet metal shears will work well on rusty metal.
Bill
   / electric metal shears? #17
Cutting rusty metal can be a challenge with most any type of cutter, including a torch, but it isn't too hard to run a wire brush over the area that is going to be cut, or if it is really rusty, maybe a light touch with a grinding wheel. Very seldom do I ever use new steel, most is anywhere from light to extremely rusty.
David from jax
   / electric metal shears? #18
I have an air powered sheet metal shears (they look like sissors) from HF and they work great for cutting the thinner metal building R panels. I don't think they would work well for cutting thicker metal such as 16 guage. For heavier metal I would use a metal cutting bandsaw, cut off wheel on a grinder, torch, plasma cutter or a saber saw.
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
Two Post Car Lift (A50120)
Two Post Car Lift...
2022 Schulte 2500 Giant Rock Picker (A55314)
2022 Schulte 2500...
