Electric motor questions
   / Electric motor questions #11
The Leeson will have slightly more power too...
SR
   / Electric motor questions #12
I made log splitter with electric motor drive.
As I'm from other side of the pond (as will my friend @Sawyer Rob tell), I'm not so familiar with your measuring system, so I'll explain it in SI (metric units) and try to convert in US units.
My splitter is driven by 3ph electric motor (3x400V, 50Hz) w. nominal power 5,5kW continuous, about 1400rpm.
Pump is 19 ccm/rev, over pressure valve set @200bar. So, about 27 lit/min flow.
At full pressure motor is loaded with 9,5kW (intermitent @200bar peak Pressure).
Hydraulic cylinder is 80/56mm dia (piston/rod), and at 200 bar splitting force is limited to 10ton.
Let put units in US:
Hyd. cylinder is 3,15/2,2in dia.
Motor 7,5HP (continuous).
Pump 1,159 cuin/rev, at 1420rpm give 7,1gpm
Pressure (max): 2900psi
With mentioned pump at 2900psi motor is loaded with ~13hp (motor is shortly overloaded 73% more then nominal power).
Now you can rough calcualate ratio:
your motor is 2hp, and as is 1ph, I doubt that you can overload it more then 50%, say 3HP max.
So 3/13*7,1...You can pull out 1,6gpm@2900psi max.
For that 1,6gpm@3450rpm, you have to buy pump with 0,11cuin/rev.
Honestly, this splitter will be very slooow (if you need force) or weak (if you want speed).
For example, if you find cylinder like I have (3,15in dia), it will move 0,8in/sec.
   / Electric motor questions #13
A 2 stage pump makes a lot of difference in the power required and work well on wood splitters. You can get 11 gpm at 600 psi or so and 2500 psi at a much lower flow.
This is what I was using as a premise that it may work.
Now to see what the theoretical tonnage force would be at the 600 psi and 3.6 gpm of the first stage.
EDIT
It appears to be 7536 lbs or 3.75 tons of force with a 4 inch cylinder.
Somewhat weaker than the advertised 5 tons of force of my DR 5 ton splitter.
Thank you ZJ_HR.
I have read and seen videos of many ideas that have come from your country. It is great to see the different ways that different societies handle a common task to all.
   / Electric motor questions #15
EDIT
Thank you ZJ_HR.
I had a 5 hp Honda gas burner on a 11 gpm 2 stage and I could only get to 2200 psi before the motor stalled in the high pressure side. The only hope of working is not hitting the high pressure very long. An electric motor will handle an overload pretty good for a brief time but I’d still look for a bigger motor.
   / Electric motor questions #16
I have 2 speeds with one pump.
You can see that shiny "cube" between operating handles, where manometer is.
This magic cube is "autospeed valve" which transfer oil to both chambers and push rod like it is plunger type cylinder. When load increases, cube opens front cylinder chamber and oil pushes full piston area at full splitting force.
For that it's necessary to have adequate ratio in piston/rod diameter.
I agree that in low power systems, like 2hp motor is, it's easier to go with 2-stage pump. Tandem pump cost more, need special hi/lo valve etc. Even with tandem pump, with 2HP power, it will have slow working speed anyway, just with faster reverse and faster "empty" forward move.
   / Electric motor questions #17
As a thought, is there a chance of `v` belt drive between the motor and the pump. By changing pully sizes the motor could be adjusted to the pump but at sacrifice in speed
   / Electric motor questions #18
You have a very interesting splitter, but I can't quite figure it out, unless - - what length are your splits? It looks very short between the push plate and the wedge. It looks like lengths are adjustable and that when in use, the overall length of the splitter is about twice as long. Do you have a picture of it in use?
I was looking at that also. It appears the end that the adjustable height wedge is fixed because of the linkage mounting on the stand.
But the other end also appears to not have much room in the hydraulic lines to move and looks to be mounted solidly to the blue stand also.
Maybe a “chopper “ that cuts across the round rather than splits?
   / Electric motor questions #20
From what I can tell, the cylinder will slide back against a hard stop in operation. (Note the flange welded to the cylinder near the rod end port).
When in storage, it will simple slide forward to reduce the space used. Very clever and awesome idea.
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
