electric motor with hydraulic pump?
   / electric motor with hydraulic pump? #11
that was my gut, but i almost think i've seen used industrial units with 3hp motors. i may be way off on the pump too. to be honest, i'm not even sure if a 2 stage pump is a workable design. it just seems logical to me to be able to move the tool up to the work at a good rate of speed, and then have it kick down a gear to do the heavy lifting, so to speak. i need to find a way to get inside a machine to see what makes them tick i guess.
An industrial 3HP motor would only power about a 2 gpm pump @ 2500psi.
Industrial applications usually dont use 2 stage pumps.
The whole theory of using the 2 stage is to be able to use smaller engines and still get the fast cycle times, because it only has to slow down when the load exceeds 650psi(which is about 4 ton on a 4" cyl).
If you tried to run a straight 11 or 16gpm pump with a motor that is sized as above, You would over current your electric motor on enything needing more than 650psi to split. And if you used a gas motor, it would stall it.
On the flip side, to actually run a 11gpm single stage up to 2500psi, would require about 19 HP electrically, more for a gas motor. It wouldn't be very efficient, but it wouldn't slow to a second stage in the split either.
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
