Electric Service Panel questions
   / Electric Service Panel questions #11
I am liking the manual transfer switch, even if in a generator-ready load center, more and more. :)
I have a manual switch and I have never regretted it. It is low-cost and highly flexible.
I could see a full-blown whole-house auto start/transfer set up for those who have a critical medical condition, are unable to physically deal with a manual generator, or for those who travel away from home often.
   / Electric Service Panel questions #12
Tom, The electric man put my switch in today it's called a Breaker Interlock Switch sold on line in Virginia,easy hookup, when you flip the switch it turns off the main so only one can work at a time,one plug, took about 1 1/2 hours to hookup very simple.
   / Electric Service Panel questions #13
Manual all the way. The automatic switch is almost useless unless you can configure it with yoru current genny to start and run when needed. They are also a third or less of the price.
   / Electric Service Panel questions #14
When I installed the manual change-over switch I also typed out a detailed instruction sheet for starting the generator, what to shut off BEFORE pulling that change-over switch (items such as the computer due to the initial power surge, shutting off the 50 amp breaker to the hot tub - can't run that off of a 7500 watt generator,) and how to make the final change over from municipal power to our generator. Laminate the sheet so it can be taken outside when it is snowing/raining.
This system has worked superbly multiple times. The power has gone off many times when my wife was home alone and that list was a God-send for her to make sure that everything was done in the proper order.
   / Electric Service Panel questions #15
I have had generators for 20 years and all sizes and a manual switch is not a bad way to go. You only need limited circuits during an outage anyway. Best use of money and maintenance for the future. From a guy that now has a whole house auto system that is over kill.
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
NEW AIR DRYERS (A55745)
NEW AIR DRYERS...
(2) UNUSED HAY SPEARS (A52706)
(2) UNUSED HAY...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
Takeuchi TL250 Skid Steer (A54865)
Takeuchi TL250...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
