Eagle1
Veteran Member
- Joined
- Jul 4, 2003
- Messages
- 2,452
- Location
- Viburnum, MO
- Tractor
- Kubota BX2200, LS XG3135H, Grasshopper and Yazoo Zturns
Skips details on modifying the ICE.
This is true but during Katrina and other natural disasters, FEMA brought in fleets of generator trucks & tankers of diesel to power the petroleum supply chain.Just a reminder that gas station pumps, refineries, fuel depots, pipeline pumps, etc., run on electricity, too.
Pretty sure I could distill alcohol, put it in our flexfuel Impala and drive it.Skips details on modifying the ICE.
As I said, you are not going to produce a gasoline or diesel substitute. But electricity is trivially flexible for many applications.
In many areas with abundant sunshine, solar PV is indeed a viable solution. Where I live, due to limited sun, I'd need an acre or more of solar panels to power my home and and EV's.Well, if that is what you believe then you should convert to EV right now!
If "The Grid" goes down, and/or the delicate supply chain of petroleum energy, the only alternative is off-grid PV solar. Can burn trees for heat but can not produce a gasoline or diesel substitute. A solar PV system equal in cost to an EV can power home and vehicle.
Very few have backup generators around here. When there is a wide spread outage, they truck them in. I'm thinking Moss has a good idea, fermenting alcohol. Multi use, burn it for heat, in a generator, drink it etc.Don't know about other states but I'll assume it had something to do with FEMA $ etc...But in FL grocery stores and gas stations (major ones) have back up generators...
It's so tasty, too.Very few have backup generators around here. When there is a wide spread outage, they truck them in. I'm thinking Moss has a good idea, fermenting alcohol. Multi use, burn it for heat, in a generator, drink it etc.![]()
