electric vs mechanical trailer brakes
   / electric vs mechanical trailer brakes #11
Swedish-fish, I have one of each. Advantages/disadvantages to each.
Surge - Advantage -no vehicle adaptation required ( other than backup lockout described above). Brakes only stop the trailer, not towing vehicle. Shoes last a long time as braking is only as needed. Going down a hill they will only brake if the trailer is trying to push the towing vehicle & only apply enough to stop the push. May be undetectable unless you realize it's not pushing. I've never sensed overheating from push.
Disadvantage -on two occasions my surge brakes locked up enough on intermittant black ice to cause a jacknife. Luckily both times were on roads wide enough that no other traffic was involved. It's interesting to look in the driver's side mirror & see 20' of your own trailer across the adjacent lane.
Electric -Disadvantage -Requires wiring & controller. Requires driver to pay some attention to controller sensitivity. I've seen drivers dragging a trailer with locked up wheels because they didn't adjust after reducing trailer load. Tend toward higher shoe wear if you get used to letting the trailer stop the towing vehicle. This happens if you set sensitivity too high & rest your foot on the brake pedal enough to activate the brake lights on towing vehicle but also activate the trailer brakes. That's a bad habit that's easy to get into because it also confirms your trailer brakes are working which can become an expectation.
Advantage -adjustibility on the go for load & road conditions. Easy to use trailer brakes only to reduce sudden sway.
All in all I prefer electric for my own use. If I had employees or others using the trailer I'd go with surge & auto reverse lockout. Electric also makes it easier to not loan your trailer if the borrower's vehicle is not wired.
One common mistake with electric brakes is inadequate ground. I have a #12 ground wire from my battery thru trailer plug to trailer frame and brake magnet ground wires. MikeD74T
   / electric vs mechanical trailer brakes #12
That's not a bad deal for that trailer. Hmmm, Rochester....that's only 167 miles from me.:p If you're not using it a lot, go for it and run the surge brakes. If you get tired of the way they work or they need to be rebuilt, convert them to electric. You would have to buy new wheel hubs if you bought another trailer with no brakes. You may be able to just retrofit this trailer. If not, at least you have something to use until somebody get you one of those round tuits!;)
   / electric vs mechanical trailer brakes #13
I might be the other odd man out here, but I have a 5-6000 lb boat rig that works great! I could be mistaken, but I think that surge brakes have had mechanical lockouts built into the brakes for years. This is my second boat that has had them. You do not have to lock the system out or use any kind of solenoid. As soon as the drum starts to reverse there is a mechanical lock out that keeps the brakes from being applied.
As with all trailer stuff, what is probabbly the largest factor is proper maintenance. Keep your hubs in good shape and inspect your brakes for wear and proper adjustment. And whatch your tires for wear (especially checking), make sure you have a spare and lug nut wrench, and do not assume the vehicle jack will work with your trailer.
Stay safe, and happy towing.
Dave
   / electric vs mechanical trailer brakes #14
SnowRidge said:
Those are surge brakes. They are desirable when you have to back into water, especially salt water, which is hard on electric brakes. They are also used a lot by trailer rental places, since they don't have to worry about brake wiring or brake controllers.
They are somewhat of a problem on hills, as the brakes may drag on a long downgrade, which can result in brake fade, perhaps when you need them the most. They are also lagging brakes, not coming on until after you step on the brakes and the towing vehicle slows, except on the long downgrades, where they may be on all the way down.
Lagging brakes don't give as good a control as leading brakes, which are possible with electric brakes, and have more of a propensity to jacknife in a panic stop than electric brakes, but aren't nearly as likely to do so as no brakes. Hope that makes sense.
How do you back them up? Slowly! :D
I would much rather have surge brakes than no brakes. :)
Proper operating surge brakes, when backing up, are inactive with a solenoid that bypasses the braking action.
Thanks for the helpful information. Here's an update.
I haven't bought a trailer yet, the seller said he'd get back to me with specifics of bed size, weight..etc. Still waiting. I was also hit with the reality of the visa bill this month and my wife doesn't see the need for a trailer right now (and she's probably right).
In the meantime I found an aluminum single axel trailer (no brakes) that I can rent for $25. Tonight I'll be towing the tractor 2 miles to church and using it and the trailer to pull a hayride. I'll be carefull and chain the tractor down well. I figure it'll give me some baseline for towing without brakes.
   / electric vs mechanical trailer brakes #16
Europe is the cradle of surge brakes, inertia brakes, overrun brakes, or whatever you call them.
All trailers above 750 kg need brakes. surge brakes are allowed up to 3500 kg trailer GVW
On older systems of 20 years ago, there was a latch with which you could lock the hitch head, so you could back up with no problem.
Recent systems have axles with automatic reverse release mechanism.
As soon as the drum turns in opposed direction, the friction of the brake pad turns them 15 degrees with, and releases the force. a kind of inversed wedge.
About the jamming, applying full brake force, being pulled loose from the brakes, then again jam full brake, is impossible with the systems we use in Europe because they all have a shock absorber in the overrun device on which the hitch ballhead mounts.
From a European perspective, i dont see any benefits of either system. In Europe, electric brakes never catched on, because the system is (was ?) notoriously unreliable.
Neither electric or surge is perfect. Just with surge brakes you dont have compatibility problems, nor corroded contact problems.
surge brakes dont come even close to air brakes, but they are a very good substitute to electric brakes...
as said, this is from a European perspective, where surge brakes are as wide spread as electric is in the USA... maybe we just dont know any better. :p
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
100 GAL FUEL TANK (A52472)
100 GAL FUEL TANK...
John Deere 9420R Tractor (A53342)
John Deere 9420R...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
