AV8R62
Bronze Member
You can usualy drive an 8' ground rod all the way with no tools
if you have a bucket of water,
make a small impression with the heel of your boot
and fill it with water,
push the rod in as far as you can and work it up and down.
add water as needed and before you know it it will be all the way down. sometimes you might have to pull it up 3 feet or so to make the rod slick again and push it back down.
a day later when the hole has settled you cannot pull it out and the top is not mushroomed.
I have installed many ground rods this way.
