Electrical Panel
   / Electrical Panel #1
B7510HSD
Veteran Member
Kamiah,ID
Kubota B2601
Can you have more than one wire running thru the same hole/clamp in the panel?? I need to run 3 more circuits and don't have any knock outs left..
   / Electrical Panel
You shouldn't run more than two cable assemblies the same hole.
Ok I can make that work I'm getting ready for a rough in inspection soon and I need to finish running the 3 circuits to the new addition!! Thanks
   / Electrical Panel #4
Make a new hole with a Lee hole puncher or whatever the term is for the tool--makes neat holes.
HTH
Arkaybee
   / Electrical Panel
HTH
Arkaybee
Ouch those are expensive..
   / Electrical Panel #7
You don't need a punch kit, just get a hole saw at the hardware store and run it on your battery drill. Very quick and easy. The same saw will cut many holes if you get a good one.
   / Electrical Panel #8
Or use a step drill bit and stop at the size hole needed for that particular circuit
   / Electrical Panel #9
While we often do install two wire per connector, you aren't really supposed to. Some inspectors are more fussy than others. You are only allowed three #12 or four #14 in a1/2" raceway. By the time you add the ground wire of the roamex, you would be over your allowable fill.....
   / Electrical Panel #10
Grnd wires don't count in pipe fill. Some inspectors don't understand load derating either.
TRUCKING INFO (A50775)
2006 Pearson Quantum Hale Pumper Fire Truck (A50323)
2006 Pearson...
Polaris 90 Sportsman 4-Wheeler (A50121)
Polaris 90...
2020 Caterpillar 420F2 4x4 Loader Backhoe (A50322)
2020 Caterpillar...
2014 Chevrolet Cruze (A51694)
2014 Chevrolet...
2014 Peterbilt 337 Forestry Grapple Truck (A50323)
2014 Peterbilt 337...
