Electrical problem might have ended badly
   / Electrical problem might have ended badly #21
I'm not sure why you would not run the dehumidifier once the wires were fixed unless there was a problem with it. Connections like this go out all the time...over time, especially the ones outside or in an area like this. I just fix and go on.
Rob
   / Electrical problem might have ended badly #22
I agree with PR:
and others that small arc will melt a lot of stuff and not trip a properly functioning breaker, not sure if the arc fault breakers will detect this or not, but I believe that this was they basis for their design... also that these breakers are more prone to nuisance tripping over the OLD NON-ARC FAULT breakers but that was why they were made. some ares they are too sensitive for use in such as garages and the like where older AC type drills ect will be used. these types of equipment operate with a certain amount of normal arching inside as the unit runs. :)
also as far as finding these small burnt areas, they are actually fairly common from what I've noticed...
mark M
   / Electrical problem might have ended badly #23
The Inspector will answer PMs, but I don't think he answers electrical questions in the forums spontaneously any longer.
   / Electrical problem might have ended badly #24
An arc-fault breaker should have prevented this.
A better practice for installing receptacles is to "pig-tail" the wires rather than "daisy-chain". By tying the two or three hot (ungrounded) wires together and taking a pig tail to the receptacle and doing the same thing with the nuetrals (grounded), you allow the load to bypass the receptacles between the load and panel.
For example-- if the dehumidifier is plugged into the last outlet on the circuit (furthest from the panel).
With the wires daisy-chained, the load travels thru each receptacle.
With the wires pig-tailed, the load travels thru the wires, bypassing the receptacles.
I hope I don't confuse anyone too much with this:eek:
   / Electrical problem might have ended badly #25
PineRidge said:
Chris I would think that a good question for the inspector. Is he still actively posting?
Mike, I actively read, but rarely post. But I will answer the question that was asked. Yes an Arc-Fault breaker would probably have identified that arc signature and tripped off. Arc-Fault breakers will identify multiple arc signatures. That one sounds like a series arc. They are also designed to trip off with a parallel arc, i.e. hot to neutral or hot to ground.
Starting in 2008, in the areas that adopt the newest version of the NEC, all 120V 15 and 20 amp circuits in a dwelling unit will need to be protected by Arc-Fault breakers or combination devices. I'm sure we will encounter all sorts of problems along the way in doing this, but I feel it will be the best thing to stop residential fies from starting.
   / Electrical problem might have ended badly #26
Inspector507 said:
...I'm sure we will encounter all sorts of problems along the way in doing this, but I feel it will be the best thing to stop residential fies from starting.
Yeah. I guess. It might end up being a pain but having seen people that have lost everything or worse to a house fire, well, you know, it is probably worth a little inconvenience.
   / Electrical problem might have ended badly #27
There are additional costs, too. The breakers are several multiples more expensive than standard breakers. I also understand that additional neutrals are required. I have seen estimates that the new requirements will add about $1,500 to the cost of a house.
   / Electrical problem might have ended badly #28
I did this on the house I built, mainly because it was easier. I put the pigtails on the receptales while watching tv at home, then wired them up at the house.
Inspector thanks for the input
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
2023 HLMK TL (A55758)
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A55788)
2012 Peterbilt 382...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
Doosan 7' Bucket (A50775)
Doosan 7' Bucket...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
