Electrical question for perfectionists... re: BX1500
   / Electrical question for perfectionists... re: BX1500 #11
bxowner said:
Thanks, Wayne. To my pleasant surprise, removing the turn signal harness did not interrupt the funtion of the flashers. I have zip-tied the turn signal harness back upon itself so that it won't flop around or be exposed to chaff.
This is why I don't often take days off... too much time to think!
That is good, they are connected together, but you have the hot going to the lights and switch and that is what counts. That is a pretty good idea to use the signal switch though. I might have done the same if I would of seen your posting before I did mine. So is life.
Take care
Wayne
   / Electrical question for perfectionists... re: BX1500 #12
They might not be a match for what Kubota uses on the tractors, but you can use marine grade switches which are better than what Kubota supplies. That way, you don't have to be concerned with water getting into them. The marine switches are also available with pilot lights in them, so you will also have a visual if the switch is left on. I would also wire them so they are on the switched side of the ignition, so when you shut the tractor off, all the lights also go off.
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
1272 (A50490)
1272 (A50490)
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52128)
New Lewis Brothers...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
