eMax 22/25 info?
   / eMax 22/25 info? #131
DavesTractor thanks for heads up. Called my dealer and he's ordering the kit and scheduling the work.
   / eMax 22/25 info? #132
They have a kit to fix the creeping, not sure if the word is out yet. It involves some shouldered bolts that fit the frame holes precisely to keep flex down, and I think a different neutral valve. Anybody with this issue might want to contact their dealer who would then contact the service rep and see if these are available yet. If not, soon. And new TLB's coming out of the DC's have this improvement. All the little SCUTS with a ladder frame have some flex, that isn't a problem. Managing the flex is key, it needs to not cause issues with any of the systems.
How hard would it be to install this kit oneself? Or is this covered under the warranty, probably minus transportation to the dealer? I don't have a hoe on mine and the creep (forward only) has been minor, just haven't gotten under it to make an adjustment.
   / eMax 22/25 info? #133
We put ours up on a lift so we can stand under the tractor and do the job. Not so easy on these low slung tractors to do the work on the floor. I'd take it to the dealer, but call first as I do not think they are putting the kits on tractors without backhoes. I suppose if it is good for a backhoe it ought to be good for a tractor with just a loader, I understand that reasoning. But as far as I know, the kits are not necessary on the units without a backhoe. I think on about every HST of all models and brands it is hard to get the pedal to always center exactly in neutral under all conditions. It's smart to make sure things are centered and set the brake when you get off. Or shut it off.
   / eMax 22/25 info? #134
What brand 3ph post hole did you buy?
   / eMax 22/25 info? #135
When will they make a hard cab to,replace the soft one? Seems to me they gave all their attention to the Emax instead of the Max, and the Emax is a freaky BX series in red.
KOMATSU D51PXI-24 CRAWLER DOZER (A52707)
KOMATSU D51PXI-24...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2003 Big Tex 10PI...
