CurlyDave
Elite Member
I'll have to look into this chain you speak of. Recomend getting this at Lowes or what?
The Lowe's in Medford, OR had it in 100' lengths in a plastic box. Be sure to get the proofcoil--it is stronger. You will also need a 10' section, which will have to be cut. They can do this at the store. Most hardware stores carry the chain, but finding one with a 100' length in stock can sometimes be a challenge. 100' of 3/8" chain is not "as light as a feather". You are dealing with heavy machinery and the chain needs to be heavy also.
I do have a 4x8 piece of 3/8 in plywood here.
3/8 is probably a little light for this job, but it may work. You do realize that even 1/2" plywood is going to be shredded during this operation.
The only issue is that it's the back end of the tractor that faces my driveway, but it's at least a hundred feet away.
This is a good thing. You want to pull on the back, plus this is what will let you get the box blade off and away on the sled. Pace off the distance and get the right length of chain, maybe some extra. If you really want to play it safe, invest in a 200' tape measure (mine was $14.95) and get the length right. Extra chain is not a problem, too short and you can add a section.
Get what are called "grab hooks" for the ends of the chain. Have someone who knows show you how to use them to "grab" the chain.
I may look into that chain/paddle idea w/ the back tires. But I'm not sure I really understand that. Guess I'll be re-reading it.
If you know exactly what you are doing, this will work, but I think it is a dangerous thing for an amateur to try by himself. Especially if you have never seen it done. There is the potential for seriously tearing something up, including your own body.
The best thing you can do here is to get a plastic toy tractor, a pencil to simulate the paddle, and some light string or dental floss to simulate the chain. Sit down at your kitchen table and model exactly how you are going to do this. Watch what happens if you spin the wheels or don't stop in time. 15 minutes and a few bucks can save you untold misery. If you use the paddle going in reverse, you have less than 1/10 of a tire revolution to stop the wheels before the paddle comes up & hits the undercarriage after it comes out of the mud. Sounds like a piece of cake, right. Well, think about the fact that the load on those wheels is going to go from high to low as soom as the paddle breaks out of the mud, plus the weight of the tractor is going to cause the speed of the wheels to increase as the wheel goes over the top of the paddle and falls back into the rut. You go from needing high torque to needing the brake in an instant...
If you are going to pull with the truck, get someone who knows what he is doing to drive it. This is not a job for your wife, unless she understands pulling things with a 4 wheel drive and has experience.
Go over and ask your neighbor with the smaller tractor to at least look at your setup before you start to pull. His smaller tractor is a lot more capable of pulling you out than your truck. This job does not require 400 horsepower, it requires a very low gear. If he has hooks welded on the FEL of his tractor to attach to the chain, this is a particularly good sign that he might know what he is doing.
Since he has 11 kids, I bet the oldest one has logged more hours on a tractor than you and I put together. It may be worthwhile to have the neighbor drive your tractor and one of his kids drive his...
