engine black heater?
   / engine black heater? #1
dirtworksequip
Veteran Member
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
I purchased an engine block heater for my JD 3520 and cannot get the threaded plug out of the engine block. Any suggestions?
   / engine black heater? #2
I have a Yamaha 4-Wheeler and the rear-end has a hex head bolt you must remove to check the fluid level. Recommendation in the manual is a light tap with a hammer to the head of the bolt. Remember, light tap!
If you can do it while attempting to turn the threaded bolt, a light tap may be all it takes.
Good luck!
   / engine black heater? #3
A long cheater bar. This is what I needed to do the same to my 4210. A little :cus: helped too.
I called the Deere dealer today to see if they had experienced similar problems and they responded that they order them in with block heaters. No help there. I used a six foot cheater pipe on a breaker bar and nothing moved. I backed off on it because the bar was bending.I guess I'll try an impact next.
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A55788)
2009 Ford F-250...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
gravely riding mower (A53424)
gravely riding...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
