MajMac392
- Joined
- Jan 8, 2002
- Messages
- 411
- Location
- Southern Maine
- Tractor
- Cub Cadet 7234, John Deere X300 Riding Lawn Mower
I had toyed with putting a Block Heater in my Cub, (23HP, 4WD, Mitsubishi) for a while and finally found a dealer that new what they were, and had one sent to me by Cub. It turned out to be a bit of a pain to get the old freeze plug out because of the tight space to work. I did take the loader off but the oil filter and a solenoid were right in the way. Well I finally got the plug out and then took me a while to slip the heater into the hole. I tightened her down (20-25 Inch Pounds) so it didn't take a whole lot of tightening. I then filled her up with coolant and went to lunch. Came back a while later, drip, drip, drip.......... /forums/images/graemlins/confused.gifI tried to tighten just a little more but to no avail. I then had to pull the heater back out, a real trick because it has a couple of molly type ears that spread in the hole after the heater is inserted. Now I'm having a job finding a replacement freeze plug. I bought one at Napa but it was to small and slid right into the block. /forums/images/graemlins/frown.gif I need to order the next size up because they don't stock what I hope is the correct one. So I my tractor is dead for a while, fortunately no snow to plow but I wish I had never bothered with this now. What is it they say about hindsight?
