Oil & Fuel Engine block heaters. How long to heat a compact tractor engine [ 3 cylender diesel}
   / Engine block heaters. How long to heat a compact tractor engine [ 3 cylender diesel}
Thanks RNuman, While we are naturally frugal with energy, we began with 4 deep cycle batts and 4 Arco 35 watt pannels. Since that system in 83 we've grown it to 3kw w one more kw yet to be mounted. I liked the sense of heating the block rather than just the oil, but a functional thermostat or timer seems like the way to go to make that doable with out spending needless watts. Thank you for taking the time to help.
Ron
"If you absolutely need your tractor, put it in a heated shed."
Dang..... you know, last week I had three or four of those and I forget where I put them.
Ron
Thanks Patches, Sorry to post such a vague question. There are so many variables to consider. Also by block heater I was thinking coolant heating block. I guess they have stuff that works from the outside of the block. Also, on the surface it seems easier to go with the btm hose system but there may be pitfalls I don't know about yet.
Ron
2009 Honda Pilot SUV (A55853)
2009 Honda Pilot...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
Margaritaville Metal Wall Decoration (A55853)
Margaritaville...
