/ Engine Idling "hydraulic lift works" increase engine speed "lift stops working"
Re: Engine Idling "hydraulic lift works" increase engine speed "lift stops working"
Thanks to all for the tips. It was exactly as all indicated... no hydraulic oil getting to the pump... or not enough. I drained the transmission housing all 13.5 gallons. I found the filter that I had cleaned good, I thought, was clogged again. I also found that the filter that i got from a tractor supply, the one in the photo, is not the correct one for my tractor. Concave end on the lower end of the filter was not a large enough diameter for that heavy duty spring to press the flat washer against the sealing O ring.
After finding this out I resorted to cleaning my new (slightly used) filter again. This time I resorted to lots of "dawn" grease desolving detergent, then fresh water, then air blowing from the inside of the filter outward, then soaking for a while in alcohol, more hp air, then soaking in alcohol gas and more hp air from the inside out. This time it is clean. I reinstalled the same hydraulic oil since it on had 10 hours run time.
I strained it through nylon panty hose and a 200 mesh fuel strainer. From what I saw in the hose and mesh strainer I think I trapped every thing larger than a gnat's whisker.
Last time I went through this messy drill... I cleaned the transmission casing out good with fresh diesel. But from what i saw today I did not get everything out. Since this tractor is old in years and sat in the weather most of time I have concluded that I may have to do this several times before everything is clean again.
Oh... the lifts works perfectly now. Again thanks for the tips and guidance. Ken
