Engine Noise
   / Engine Noise
I removed the input and output fuel lines to the injectors and removed the 2 bolts and the piece it holds down. I'm not sure how to take them out now. Could somebody help me out?
Mark
   / Engine Noise #22
Mark
Simply pull them straight out while rotating. They are not threaded in. You may need a heel (crowfoot) bar if they're carboned in pretty bad. You can also try a few drops of penetrant around the injector body.
   / Engine Noise #23
Sometimes you can turn the engine over and the compression will pop them loose.
   / Engine Noise
I got them out. I thought they just pulled out but the first one was stuck and I wanted to make sure I wasn't missing anything before I applied a little force. One just pulled out easily. Thanks for the help.
Mark
   / Engine Noise
Had the injectors checked and 2 opened at 2000 psi and 1 was 0. Will order 1 and post the results when I get it back in. I hope that's the problem.
Mark
   / Engine Noise #26
Mark
They found the dribbler! Good for you. :thumbsup:
Should run like a champ now.
Curious how much they charged for the testing if you don't mind. :)
   / Engine Noise
He said the 2 had a good pattern at 2000 psi and the bad 1 was a straight stream holding no pressure. He said normal for their tractors is 3000 to 3500 psi. I dropped them off at a John Deere dealership and he said it didn't take long so he didn't charge me anything. I was suprised because I have only been in there 2 or 3 times and I know they didn't know me. Will probably be 3 or 4 days before I get the new injector. No mail today so will go out tomorrow. Didn't want to pay for overnight delivery.
Is there a torque setting for the injectors?
Thanks to all for the advice and help
Mark
   / Engine Noise
The injector I ordered came today. I installed it and the tractor is back up and running. Thanks for the help.
Mark
   / Engine Noise #29
Glad it was such a simple fix.
Chris
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
New Long Forks (A53002)
New Long Forks...
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
