Engine oil change Interval Jd 3520
   / Engine oil change Interval Jd 3520 #11
If I put on maybe 100 hours a year and it is recommended to change every couple hundred hours or yearly, am I better off changing the oil in the late fall or the spring before the mowing starts? There is not much use after November.
   / Engine oil change Interval Jd 3520 #12
I would change it in the spring so you can start with fresh oil before the heavy use season but I don't think it matters much either way.
   / Engine oil change Interval Jd 3520 #13
I do mine in the fall so I'll have nice clean oil in it's best state for all the cold weather starts it will get.
   / Engine oil change Interval Jd 3520 #14
I can agree with that logic. My reasoning for the other way is acids build up and oil deteriorates over time so if you change in the fall your oil will be getting older and worn by the time your heavy uses season rolls around. In all reality it probably doesn't matter much either way. I have a ton of things with engines and sometimes something that doesn't see a lot of hours slips by and goes over a year without an oil change and I haven't had any problems yet.
   / Engine oil change Interval Jd 3520 #15
I'm in NE. What makes you think winter is my low use season? :)
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2016 Ram 3500 High Top Service Truck (A52377)
2016 Ram 3500 High...
