Engine oil pressure light
   / Engine oil pressure light
It appears to be a bad sensor. Put a gauge on it tonight and pressure never got below 45 psi in idle and was at 62 psi at high rpm. 😅
   / Engine oil pressure light #12
Awesome! You had the same feeling of relief I had with my dozer. :)
Completely. Now I have to figure out what's going on with my power steering. If I turn to the left it is fine. If I turn to the right no power steering at all. My front axle was a little low on fluid, maybe a pint, but once topped off it still steers the same way. Any more suggestions? The power steering pump gets its fluid from the hydraulic fluid and that is full.
HOMEMADE TREE STAND W/ STEPS (A51248)
HOMEMADE TREE...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2012 Morooka MST1500 Crawler Carrier (A52384)
2012 Morooka...
10x16.5 Tire Assembly (A53472)
10x16.5 Tire...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
