engine racket and smoke
   / engine racket and smoke #1
Gittyup
Elite Member
Mid Atlantic
Kioti CK25 Shuttle Shift, loaded tires, JD X739
Tonight I was loaning a buddy my boxblade. While we were loading in his trailer my tractor was idling and then the engine started rattling badly with some black smoke. After about 5 seconds it stopped and the engine went back to running normally. I went on to use it with it running for at least the next hour with no issues. What could have been the problem and can I expect for more bad things to happen?
   / engine racket and smoke #2
Check your fuel bowl/filter for any water or contaminants. When did you last change fuel filter? Is your fuel supply clean and fresh?
Fuel is clean and fresh and treated with power service. Probably could use a fuel filter change. It sits a lot these days. So hour wise, not ready, but it's been a while in time.
   / engine racket and smoke #4
Maybe a little crud made it to one of the injectors or one was sticking a bit. Sounds as if it was loading up a cylinder and then fixed itself. I think you'll be fine. Maybe add a little extra power service to the tank. It won't hurt it. If it was the IP, I think it would still be running bad. I change my filter by engine hours. Not how many months. Mine is eight years old and just over 500 hours. Never had a problem doing service by the hour meter.
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2016 Ford F450 (A49461)
2016 Ford F450...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
