Engine RPM Surges also loss of coolant (possible overheat)
   / Engine RPM Surges also loss of coolant (possible overheat)
update on the fuel filter change?
I might be reviving an ancient post that started...
I eventually replaced all fuel lines, fuel filter, filter screen in fuel tank and the manual lift pump. I still have occasional problems with the RPM surging and then the tractor just dies. The only way I get it to start up again is if I disconnect the fuel line going to injector #1 and "bleed" the air out of the system there. After that the tractor may run 5 minutes or 5 weeks. It is so random. It is like I am getting air in the fuel system, but I can find no leaks, and everything appears okay. However there is definitely a problem somewhere. I have been struggling with this on and off every since my original post.
   / Engine RPM Surges also loss of coolant (possible overheat) #12
spray all the hard lines off with carb cleaner, wipe down with a paper towel next time you put her up. after setting, run a clean dry paper towel all over the lines, see if any of them have a weeping oily residue on there where there might be a fuel leak. when setting, a little fuel may leak out and cause an air bubble.
2018 Chevrolet Camaro 1LT Coupe (A55853)
2018 Chevrolet...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
