Engine Speed and Shifting Question
   / Engine Speed and Shifting Question
Thanks for all the replys,
I've never had any grinding problems when shifting like this. Even though I'm throttled up about 3/4, I always stop before changing directions. Like I said earlier, the tractor handles the change very well, never grinds, and the gears or so slow in low range that I dont have any jumping or surging when changing directions, very smooth, and my pto stays powered up in case I have limbs or brush under the cutter.
I only do this when running the cutter, otherwise I would just use the foot throttle, and power up and down, but the cutter runs much better when left powered up.
   / Engine Speed and Shifting Question #12
Your shuttle shift and clutch on your Mahindra will take it for years & years, that's what it was designed for. I imagine your tractor probably uses the electro/hydraulic engaged PTO like my 4110 and clutching the tractor doesn't have an effect on the PTO if you have the switch in the manual position. I run my cutter at full rated RPM's and shift forward & reverse alot every time I cut, I run it around 1500 rpm's when doing loader work and constantly shuttle shift - hasn't caused a problem in 1750+ hrs. I can shift without coming to a full stop even. If you do ever get any grinding when shifting you need to check your clutch adjustment and/or your shift cable adjustment. Keep on workin' !!
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
MONITOR WITH BUILT IN COMPUTER (A53843)
MONITOR WITH BUILT...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
JOHN DEERE 6615 TRACTOR (A51406)
JOHN DEERE 6615...
