engine speed using fel
   / engine speed using fel #11
I think it will depend on the particular tractor model, and how the pump is set up. I normally run 1800 to 2000, but I need to go to 2400 or so to get maximum lift. Often I'll set it up at 1800, and use the foot throttle to goose it before I dig in.
   / engine speed using fel #12
jeez..
I thought that running up the RPM's gave you speed only, never thought of increasing it for more power.....what an idiot!
I always run near idle, figured if it couldn't lift it because the bypass was kicking in...
thank God fot tbnet! /forums/images/graemlins/laugh.gif
   / engine speed using fel #13
to add my 2 cents i usually run about 1800-2000- rpm when working with the fel, unless it is really easy stuff, but i find 1800 to be adequate for most fel work.
   / engine speed using fel #14
Well, it does speed it up too - and if I don't need the lifting power, I often find the faster response to be anoying, which when combined with the increased racket, is why I usually keep the RPMs down. Essentially, turning the pump faster gives more pressure and volume, which I think correspond to power and speed, respectively. The bypass will limit the pressure, and the pump will have a maximum volume it can move.
   / engine speed using fel #15
I run at 1500 or below, a 4330 Kobato. I did slow unless it's some brought in fill dirt or something like that. I need me a tooth bar I think.teddydo
2018 Allmand Light tower (A49461)
2018 Allmand Light...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2016 Ford Taurus SE Sedan (A48082)
2016 Ford Taurus...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2003 Ford F-150 Pickup Truck (A48081)
2003 Ford F-150...
