I spent about an hour yesterday checking bolts, tires, wheels, etc. I found 1 or 2 of the FEL bolts that were about 1 turn loose. I also tightened the lugs on a wheel that I had removed a few months ago to get a tire plugged. That same tire was about 20 lbs low in air.
I took it out and gave it a test run. I couldn't get it to vibrate at all. I drove it on the same hard driveway, in the same gear at the same rpms....no vibration. I tried all gears on pavement, gravel and dirt ... no vibration.
I am not sure if any of the small changes caused the vibration go away. It may have been the box blade that caused it previously. I am not certain but it is gone now.
thanks for all the help.
