spruce Deere
Veteran Member
- Joined
- Feb 1, 2009
- Messages
- 1,085
- Location
- Northmost Idaho
- Tractor
- John Deere 790 with loader LS xr3140h also with loader plus a cab
Been a longgg while since I last posted.... Get comfortable if interested in the following story.
So, had a hydraulic pump let loose and being they are bolted to the timing cover of the engine and driven from the engine from gears within the cover the hyd oil from the failed pump tried to relocate ALL of the hyd oil to the crankcase.... It did not all fit...
First, there was extreme exhaust smoke, laboring engine which at this point I shut off the engine. I had just started it and all this happened in less than a minute.
Second, Finding my way threw the horrible smoke I pulled out the engine dipstick and a fountain of oil erupted from the dipstick tube.
The only good thing is that the tractor is in my shop whisle all this went down, Checking the tranny/hyd. dipstick confirmed my thoughts on what just happened.
So, I had a used hyd. pump on hand and swapped out the pump on the tractor with it. I changed the engine oil and filter, Should be on a better path now...
As I started the engine on the tractor, I expected some more intense smoke and some rough running for a bit. Well, the smoke thinned but never did clear. The rough running start leveled into a straight-up misfire on the no.1 cylinder. I betcha, it fouled the injector I assumed. I pulled off the exhaust manifold and confirmed oily diesel crud from no.1 hole. the other two ports were dry.
Had a few days wait for a new injector and the puller kit. Then some brute force whaling on the puller to pull the old injector out I was once again met with a miss on no.1 cyl with the new injector? I spoke in a sailor style tongue as the cause of miss is discovered to be deeper now.
Day or two later, I pulled the head off the block. cylinders looked as they should for only having 1000 hrs, zero ridge cross-hatch marks very clear, but as I turned the engine over by hand no. 1 piston was NOT making it all the way to the top like the other two pistons did, bent rod. So I commenced to pulling the inspection plate off from the oil pan on the engine to remove said bent con rod.
Rod removal did go good. Rod was very obviously bent. bearings and crank journal completely fine.
891 clams at deere and a couple days wait got me a NEW hyd. pump, NEW connecting rod/W bearings, pin bushing and gaskets I need to put this project back together.
After getting everything from deere, I meticulously checked/assembled everything. All cylinders made it to the top of the stroke, Checked the valves for obvious damage, there good, checked push rods for bend, zero. Plopped the head gasket on the block, torqued the head down in the 3 step procedure, returned the push rods to there rightful holes, fiddled a while getting the rocker arm rack and push rods back together, rotated the engine and lined up timing marks on the fly wheel and got all of the valves set to .008 inch clearance. All tech data is right from the deere 790 repair manual I gladly purchased couple years back.
Leaving the rocker cover, water pump/radiator, exhaust manifold off, I fire tractor up. Rough at first typical smoke but still no.1 misfire.....
Anyone got any ideas on what I missed
