Epoxy Metal to Plastic Recommendations
   / Epoxy Metal to Plastic Recommendations #21
PC7 is good stuff too. More of a filler than glue though it will glue stuff together.
Good for boat hull repair.
Ben
   / Epoxy Metal to Plastic Recommendations #22
you know for what he is doing I bet some 3M 5200 would work just fine
   / Epoxy Metal to Plastic Recommendations #23
JB Weld would be my first thought as well. I wonder if Gorilla Glue would work?
   / Epoxy Metal to Plastic Recommendations #24
If all else fails mix some flour and water and use it as glue /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Egon
   / Epoxy Metal to Plastic Recommendations #25
no use this
   / Epoxy Metal to Plastic Recommendations #26
Forget trying to stick anything together with the glue. Just go for the big sniff. After a couple minutes you won't care about anything. Works for me. Waaaa hoooo... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Epoxy Metal to Plastic Recommendations #27
I've had good luck with jbweld on all but ruberized plastics.. and some vinyl's.. though abs, and PVC are fine.
PC7 or PC-11 is an epoxy past that is also fairly tacky with plastics, as well as a few epoxy sticks that are plastic menders.. especially the ones for car battery repair.. they stick to some slick plastics.
Roughing up the surface doesn't hrt either..
clean well with alcohol or other residue-less solvent.
Soundguy
The JB Weld worked out real well, the plastic and magnet are one. /forums/images/graemlins/grin.gif
Another question for you all, I put some plastic wrap on the bottom of teh magnet to prevent the cab top from being scratched by the metal to metal contact. Any suggestions for a plastic coating for the magnet that will wear better then thin plastic wrap, but will let the magnet hold the strobe in place?
   / Epoxy Metal to Plastic Recommendations #29
Try Plasti-Dip, I think that is the name. Home Depot sells it, in the tool coral. It is used to dip tool handles in to replace the coating on plier handles, and I have used to put a rubber-like plastic coating on my file handles. I think it is about $6.00 a can. You can even thin it a little if you need to brush it on.
Edit:
I did a search for "plasti-dip" came up with this picture HERE
Kenny
   / Epoxy Metal to Plastic Recommendations #30
Better yet.. those companies that make the plastic dip and plasti-coat also make a spry application.. It's great for spraying the ends of closetmade shelving after cutting it with a bolt cutter. Sprays on decently thin.
My next choice would be appliance epoxy paint...
Soundguy
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2014 Ford Escape (A50324)
2014 Ford Escape...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
