Essentialube from Hydrotex?
   / Essentialube from Hydrotex? #1
KennyV
Elite Member
Kansas, Butler county, Just east of DooDah
Kubota L4200 GSTCA
Anyone familiar with essentialube? It is a fuel and oil additive. I have came across a drum of the stuff and wonder if anyone is/has used this?
It was intended for gasoline and diesel engines. This drum has to be over 25 years old...
I am wondering if it could be used with todays catalytic systems and ethanol gasolines, or with todays low/no surfer diesels? KennyV
   / Essentialube from Hydrotex? #2
I'd pass on it. After 25 years who knows what it has broken down to. There's no point in taking the chance of damaging your equipment.
   / Essentialube from Hydrotex? #3
Haven't heard of that stuff in a long time - during my apprenticeship with Cadillac & Oldsmobile in the early 70's we used it for cleaning carbon from those big blocks' valves, and in the oil too for de-gunking lifters. Worked fantastic - a little better than ATF. It still smoked the whole place up but it really did the job. We'd run the engine up a little and trickle it down the carb for about 1/2 the quart then dump a bunch all at once to kill the engine then let it set overnite. If there was some left in the can , it would go into the oil. It was a little less expensive than GM top engine lube and worked just as good or better. If I remember right it was manufacured in Texas. I think I'd pass on it too, not knowing how stable the stuff was for long periods.
   / Essentialube from Hydrotex? #4
If the drum isn't properly sealed I would not use it. Essentialube is still a widely used product. It is made everyday and can be purchased through Hydrotex.com, you can get it in a spray bottle, quarts, single gallons, 20 gallon drum ,55 gallon drum or a 275 gallon plastic tote.
John Deere MX5 Shredder (A47484)
John Deere MX5...
2001 Chevrolet C6500 Wrecker Tow Truck (A44571)
2001 Chevrolet...
Homemade 16' 2 Axle Trailer (A44502)
Homemade 16' 2...
John Deere Pull-Behind Dry Fertilizer Spreader (A44571)
John Deere...
2025 Dig Master DM100 UNUSED Mini Excavator (A47484)
2025 Dig Master...
2014 Harley-Davidson FLHP Police Road King Motorcycle (A44572)
2014...
