It's a yerfdog 'scout' TSC and Sams club sold them... they also made 2 styles of go-karts for kids .... the co went out of business, but a holdings company owns them now and has some parts support. A lil research seems to indicate the man who owned the co has opened before selling similar machines.. just can't seem to keep the co's open for mor ethan a few years at a time.
I keep the oil changed in mine.. and hope she stays running.. the engine and tranny/diffy are 1 piece.. likely chinese.. I have seen them in some other small gas engine vehicles.. the pip tubing frame is welded up around the engine.. so I'm not sure a retrofit would be too easy..
so I'm hopiong to get my money out of her.. though probably won't. I got her on clearance from TSC .. so far that looks like I've paid about 50$ per hour to use her thus far based on the time on the clock
So far only issue's I've had with here were:
bad / poorly written service instruction booklet.. there is a gear oil fill on the lower end unit and some sort of opening to a cavityaround the lower end housing on the same unit.. both are about 1 inch apart and have the same bolt closing them off.. the manual directions are vauge as to which is the gear oil fill.. so the first time I serviced the lower end, I was adding oil to one hole, and saw it dribbling out around the bottom housing
tube frame was made around the engine.. so checking or adding oil to the rear end or the engine requires you to use a flexible tube to snake under the rear tilt bed after lifting it, so you can get to the fil lholes on top of the engine/tranny assembly, which is rightg under the bed with about 2" clearance..
starter power is a direct line, and all aux power is thru a fuse.. the holder is in a spot that is open to the bottom, so hitting a mud puddle douses the fuse with water, coroding the brass holeder so next time you want to start, you have to pop the plastic cover off, and rotate the fuse around.
fixed that with a piece of flashing and then grease potted the fuse... no more isues there.
tranny shift is a boat throttle linkage.. if you don't exercise it, it gets stiff.. a lil cable lube hels that though.
was once driving here and front wheel cambered out. i stopped her before anything broke.. what basically looke dlike a lower control arm ball joint had come apart.. I couldn't find a nut to put it back together and was getting desperate when i noticed the nut looked alot like a lugnut on an ford 8n front wheel... had a box of used ones.. what do you know.. same thread and size..
soundguy
