Ethanol, myths and realities
   / Ethanol, myths and realities #41
Its interesting that as I search for infomation I get various value but the trend seems to be as Richard says. The process is improving and we are getting more gallons per bushell.
My other question, is how many gallons of oil can I get per acre so I can run the truck and tractor. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Looks like I need 5 bushels to get a gallon of corn oil. So then I need 15 to 30 acres of corn! YIKES! /forums/images/graemlins/grin.gif Might have to by a gas truck and tractor!
/forums/images/graemlins/blush.gif
Later,
Dan
   / Ethanol, myths and realities #42
Later,
Dan
   / Ethanol, myths and realities #43
Dan,
There is an article someplace and I will try and find it that shows how you can take an acre or two of corn and convert that to alcohol to run your car and have enough to run a corn stove and provide all of your energy needs for the year.
   / Ethanol, myths and realities #44
Dan,
   / Ethanol, myths and realities #45
Just for interest; ethanol has a higher octane content than most gasolines. This means a higher compression ratio engine could be used witch should give better effiency.
From a guessing aproach I would assume that engine design and and the ethanol/gas mix would have to be complimentary to each other. ???
Egon /forums/images/graemlins/grin.gif
   / Ethanol, myths and realities #46
   / Ethanol, myths and realities #47
E85 will damage the material used to seal the cast aluminum. Meters are cast aluminum.
   / Ethanol, myths and realities #48
Perhaps, but why has GM been makeing some of their vehicles to run on E85 then ?
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2017 John Deere 5090GN (A53317)
2017 John Deere...
John Deere S660 Combine (A59814)
John Deere S660...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
