Eurocardan PTO Shaft
   / Eurocardan PTO Shaft #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I have Eurocardan PTO shaft connecting my JD and finishing mower. There is a plastic guard over the shaft (bell shaped at the U-Joint ends).
I cannot figure out how to disconnect the shaft. I want to remove the mower deck.
I've felt around under the "bells" for a pin or quick disconnect sleeve to no avail.
Thanks for any assistance!
   / Eurocardan PTO Shaft #2
Is there a collar you can pull back or turn that will allow the shaft to slide off?
Egon
   / Eurocardan PTO Shaft #3
What "end" do you want to disconnect...?
If at the tractor PTO end... most Eurocardan yoke's have a "button type plunger" you just depress and the yoke slides off...
At the gearbox/implement end... you should have a shear bolt to remove... and it slides off...
   / Eurocardan PTO Shaft #4
John, on the implement end, with a shear bolt, don't you also have to remove a horseshoe clip, or snap ring, from the end of the input shaft before you can pull the PTO shaft off?
   / Eurocardan PTO Shaft #5
<font color=blue>...also have to remove a horseshoe clip, or snap ring, from the end of the input shaft before you can pull the PTO shaft off?...</font color=blue>
Yes... snap ring... /w3tcompact/icons/smile.gif
Those 10 cent items always seems to get ya in trouble... /w3tcompact/icons/wink.gif
   / Eurocardan PTO Shaft #6
Just curious...Normally there's no need to disconnect the gearbox end of a PTO shaft, correct?
   / Eurocardan PTO Shaft #7
<font color=blue>...Normally there's no need to disconnect the gearbox end of a PTO shaft, correct?...</font color=blue>
Correct... I just tried to cover all the bases... I really don't know what "end" he's having trouble with...?
   / Eurocardan PTO Shaft #8
Mike, if you have a shear bolt instead of the slip clutch, I think it's a good idea to take the shaft off occasionally and clean it to make sure it hasn't corroded onto the input shaft so it couldn't turn even if the shear bolt sheared. Does that make sense? But of course, I'm saying to do as I say; not as I do; I've never taken any of mine loose at the gearbox; hope they're not corroded on there./w3tcompact/icons/crazy.gif
   / Eurocardan PTO Shaft #9
<font color=blue>Does that make sense?</font color=blue>
Perfect sense. /w3tcompact/icons/smile.gif
<font color=blue>But of course, I'm saying to do as I say; not as I do;</font color=blue>
Makes perfect sense as well. Been there! /w3tcompact/icons/wink.gif
   / Eurocardan PTO Shaft #10
Roy, the cardan shaft made in Italy disconnects by rotating the knurled collar as opposed to pulling back on the collar. It will be obvious which way to rotate as it will only go one way. It works well and I find it disconnects even easier then the pull collar type. Rat...
FRONTIER GM1060E LOT NUMBER 249 (A53084)
FRONTIER GM1060E...
2018 TAKEUCHI TB290 EXCAVATOR (A51246)
2018 TAKEUCHI...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
JOHN DEERE 3033R LOT NUMBER 225 (A53084)
JOHN DEERE 3033R...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
