Excavating Yard
/ Excavating Yard #1
Mac25
Danville, IN
Kubota B2320 HST with LA 364 FEL
What is the popular opinion on excavating a yard? I need to dig up about 4-5 inches of sod and dirt for a pole barn and driveway. I have a FEL and grading scraper with scarifiers. Will this do the job or is there a better attachment out there such as a tiller? Thanks
Sent from my iPhone using TractorByNet
/ Excavating Yard #2
Lacking anything with scarifiers I used my tiller set to two inches on hard ground. Actually I got it down to lowering the FEL and scooping up the loose dirt while at the same time engaging the tiller on the same pass. I changed the slope of the bank along a creek this way. Probably moved 12 yards of dirt in a few hours.
/ Excavating Yard #3
Do you have loamy top soil? The reason for removing the sod is that it's full of organic material and over time it will decay and settle on you. The goal is to get down to a solid base, like clay soil, where there wont be any settling. What I see people do wrong is they did out material that is perfectly fine if left there and then pay for material to fill the hole the dug.
As for digging, you should be fine with what you have. Just tear it up real good and take your time.
Eddie
Amadas SPC-6 (A64119)
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
UNVERFERTH 14' FIELD CULTIVATOR (A63291)
UNVERFERTH 14'...
iDrive TDS-2010H...
