Exhaust repairs
   / Exhaust repairs
I do not think there will be a problem with the hydraulic oil getting hot. There is 4 inches of open space between the exhaust manifold and the hydraulic oil return pipe. I can take a picture from the side if you would like.
   / Exhaust repairs #12
Great alternative solution to spending $700.
Good looking job as well.
I too have fabbed up a couple of DIY systems over the years, for sure a dyno test would not confirm optimum performance but then for $$ in pocked 97% is perfectly acceptable, and that is not counting the satisfaction of a DIY solution.
Was mentioned a possible heat problem, easy cure; couple of spacers and tack weld a heat shield about 1/4" away from the manifold.
I do notice your outlet is upwards facing.
Rather than the tin can cover you might wish to add a flapper valve to keep out water.
   / Exhaust repairs #13
Good deal!
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2013 John Deere 8360R MFWD Tractor (A53342)
2013 John Deere...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
